    Results 1 to 3 of 3
      May 2006
      Et Wheels & Gto Backspacing
      Hi,
      I am new to this form. Two questions.
      1. I am considering buying ET CLASSIC 5 wheels for my 67 & 69
      GTO to interchange. Is anyone using these on their rides?
      Does anyone have pics of these wheels?
      2. What type of backspace can I use for a 67 & 69 GTO or
      A-body car? Was thinking of 16 X 8" with a 5" or 4 3/4"
      backspace. Will that work. Would use 14 X 7" or 15 X 7"
      with 4 1/2" backspace on front.
      Any help would be appreciated.
      sd389421
      Sep 2004
      Southern NJ
      Here's a good place to start: http://www.oldsmobility.com/fitting-wheels.htm.
      8" wheels need around 4.5" backspacing on early a-bodies, depending on which rear end your car has. A little more in the rear should be fine for the '67. The '69 will take more backspacing front and rear, as much as 5.5" with a 17" wheel, but that won't fit the front of a stock '67.
      There are going to be differences between '67 and '69, but I'm sure you can get a set that fits well on both.
      Matt
      1965 Pontiac GTO – Spotts 421 Tripower | TKO600 | 3.90s | Vintage AC | Baers | Hotchkis/SPC/BMR Suspension | Intro Vistas | BFG KDW Redlines | 06 GTO Seats
      Again..
      I have a chevelle and needed 5,5 bs minimum with 10s..
