Results 1 to 16 of 16
Thread: Wheel Suggestions
03-19-2006 #1
- Join Date
- Jan 2006
- Location
- New Jersey
- Posts
- 323
Wheel Suggestions
I might have to go with different rims because of backspacign issues. What would look good on my car. Im thinkin chrome lip with dark centers and studs. Tell me what you think and leave a link or pic for the wheels if you could. Thanks!
http://www.hotrodders.com/forum/atta...achmentid=67781969 Camaro SS aka Jumpin Jack Flash
World All Aluminum 427
and tko-600 attached to that
http://www.cardomain.com/ride/2305230/1
03-20-2006 #2I like the ones you got.
"Champagne taste on a beer pocket book."
03-20-2006 #3
- Join Date
- Jan 2006
- Location
- New Jersey
- Posts
- 323
you think i should get the same one swith jsut different backspacing?
03-20-2006 #4
New to Pro-Touring
- Join Date
- Feb 2006
- Location
- Blacksburg, VA
- Posts
- 25
Are those Budnik Fontanas?
Neil Croy
97 GMC Sonoma
03-20-2006 #5Which wheels have the wrong backspacing...the fronts look good the rears may look as if they need more. Hard to tell from the pic. What is the size, width, and spacing your running now?
03-20-2006 #6
- Join Date
- Jan 2006
- Location
- New Jersey
- Posts
- 323
245/17 in front and 275/18 in rear the fronts hit tie rods because i have 2 inch drop spindles now. i need 4.5 inches or less of backspacing and i have 5 right now. The picture i sent you is before the gw upper and lower control arms, spindles and dropped springs. And yes they are fontanas.
03-20-2006 #7I love the Fontana's, so since you have to replace them I would just replace the front two. If you want a new look you can have Budnik brush them and leave the lip polished...my 2 cents....I just read your other, put the stock spindles back on.
03-20-2006 #8
- Join Date
- Mar 2006
- Posts
- 3
I take it no mini-tub or narrowed rear-end in it? I like the look of the Fontanas you have.
03-20-2006 #9umm........
why not just change the spindles?Brian
'68 Camaro
03-20-2006 #10
- Join Date
- Jan 2006
- Location
- New Jersey
- Posts
- 323
I wasnt going to but now i am! me and pops fianlyl agreed that its the best way. back to stock!
03-20-2006 #11wheel suggestion
the rims you have look similar to the ones i have i know those are more expensive but i am only 19 and couldnt drop a grand on rims but they do look similar
1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
http://http://www.cardomain.com/ride/2246580
03-20-2006 #121969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
03-20-2006 #13wheels
03-20-2006 #14
- Join Date
- Jan 2006
- Location
- New Jersey
- Posts
- 323
thanks i got my problem fixed nad i wont be needing rims! thanks god..i love mine
03-21-2006 #15You have 3 inch drop springs in the rear? Your car sits a little high for that much drop. The car looks great. I have a 69RS same color with white stripes. I have the Vintec dish by Billet Specialties. 17 x 7 front 4.5 bs they fit really well. I wish I had gone with a 235 tires. I like the thinner look. I have 17 x 9.5 w/275/40/17 rear. Had to trim the fender lip a bit. I am going to lower it another inch. What type of springs did you use in the rear?
69 RS Rat. Ocean View, De. 19970 If you wake up and you can put your feet on the floor, IT'S A GOOD DAY!!!
03-21-2006 #16
- Join Date
- Jan 2006
- Location
- New Jersey
- Posts
- 323
the picture in my sig is before i did all teh suspension work. i think i should take it off because it misleads to many people. the back is verrrry low now and im just going to keep the stock spindles with gw upper and lower c-arms and if need be ill do the guldstrand mod. its should be easy with the tubular arms!
