    Results 1 to 16 of 16
      New Jersey
      Wheel Suggestions
      I might have to go with different rims because of backspacign issues. What would look good on my car. Im thinkin chrome lip with dark centers and studs. Tell me what you think and leave a link or pic for the wheels if you could. Thanks!
      http://www.hotrodders.com/forum/atta...achmentid=6778
      1969 Camaro SS aka Jumpin Jack Flash
      World All Aluminum 427 and tko-600 attached to that
      http://www.cardomain.com/ride/2305230/1
      Northern Indiana
      I like the ones you got.
      "Champagne taste on a beer pocket book."
      New Jersey
      you think i should get the same one swith jsut different backspacing?
      Feb 2006
      Blacksburg, VA
      Are those Budnik Fontanas?
      Neil Croy
      97 GMC Sonoma
      Northern Indiana
      Which wheels have the wrong backspacing...the fronts look good the rears may look as if they need more. Hard to tell from the pic. What is the size, width, and spacing your running now?
      New Jersey
      245/17 in front and 275/18 in rear the fronts hit tie rods because i have 2 inch drop spindles now. i need 4.5 inches or less of backspacing and i have 5 right now. The picture i sent you is before the gw upper and lower control arms, spindles and dropped springs. And yes they are fontanas.
      Northern Indiana
      I love the Fontana's, so since you have to replace them I would just replace the front two. If you want a new look you can have Budnik brush them and leave the lip polished...my 2 cents....I just read your other, put the stock spindles back on.
      I take it no mini-tub or narrowed rear-end in it? I like the look of the Fontanas you have.
      Los Altos CA
      umm........
      why not just change the spindles?
      New Jersey
      I wasnt going to but now i am! me and pops fianlyl agreed that its the best way. back to stock!
      zachary louisiana
      wheel suggestion
      the rims you have look similar to the ones i have i know those are more expensive but i am only 19 and couldnt drop a grand on rims but they do look similar
      1969 camaro ss 372,hotchkis tvs, comp cams 268xe, world products heads, zz4 intake, 670 holley, msd setup eagle alloy 212's, autometer ultra lites......99 console with megashifter, ls1 brakes and a soon to be 700r-4
      http://http://www.cardomain.com/ride/2246580
      zachary louisiana
      zachary louisiana
      wheels
      New Jersey
      thanks i got my problem fixed nad i wont be needing rims! thanks god..i love mine
      Ocean View, Delaware 19970
      You have 3 inch drop springs in the rear? Your car sits a little high for that much drop. The car looks great. I have a 69RS same color with white stripes. I have the Vintec dish by Billet Specialties. 17 x 7 front 4.5 bs they fit really well. I wish I had gone with a 235 tires. I like the thinner look. I have 17 x 9.5 w/275/40/17 rear. Had to trim the fender lip a bit. I am going to lower it another inch. What type of springs did you use in the rear?
      69 RS Rat. Ocean View, De. 19970 If you wake up and you can put your feet on the floor, IT'S A GOOD DAY!!!
      New Jersey
      the picture in my sig is before i did all teh suspension work. i think i should take it off because it misleads to many people. the back is verrrry low now and im just going to keep the stock spindles with gw upper and lower c-arms and if need be ill do the guldstrand mod. its should be easy with the tubular arms!
