View Full Version : 200r4 vs 700r4 tailshaft question.
MuscleRodz
02-02-2006, 08:36 PM
Does the 200r4 and 700r4 have the same tail shaft bolt pattern?
Mike
myclone
02-02-2006, 10:28 PM
Im assuming that youre talking about the tail shaft housing portion where the speedo gear is located? If so then they dont have the same bolt pattern since the 200 doesnt have any bolts holding the tail housing on.....the 200 has a one piece case front to rear :hmm: .
HTH
MuscleRodz
02-03-2006, 10:00 AM
Thanks. That is what I need to know. What tranny was used in the Syclones and Typhoons? 700r4?
Mike
myclone
02-03-2006, 01:21 PM
Mike
Mike,
The sytys used the 700 but be aware that they are known to come apart with the amount of tq even a stock syty can produce coupled with the AWD.
After more than 20 broken 700s Im stepping up to an 80 and that trans is on the wish list of 99% of syty'ers so that should give you an indication of the issues we've had with the 700. Its a good trans but it just doesnt tollerate tq and traction very well.
