    Results 1 to 15 of 15
      Oct 2014
      Change Steering Wheels
      Hey folks,
      I bought a 70 Nova SS, mostly restored, with a corny Grant steering wheel:
      http://www.grantproducts.com/products/view/49/
      I'm looking at changing it to something else. Possibly...
      http://www.detroitspeed.com/Steering...ing-wheel.html
      Is the changeover pretty straightforward? Any issues to be aware of before diving in?
      Many thanks!
      Dec 2008
      Detroit
      Quote Originally Posted by Steel409 View Post
      Hey folks,
      Many thanks!
      Should be straight forward. You will require another steering wheel hub that they sell on the DSE site.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Sep 2015
      Rockvale TN
      Oct 2014
      Decided to shift gears a little bit and would like to go with a Sparco wheel. Sparco has informed me that they do not have a hub that could work with my Nova, even though they have a hub part number listed in their accessories as, "STRWL HUB CHEVY 68>82". I asked if that one would fit a first gen F-body, assuming the steering columns between my '70 Nova and a '68-'69 Nova are identical, and they didn't know. (Which I thought was odd.)
      Does anyone know if the Sparco hub will work with my Nova steering column? Far fetched question, will the Grant hub work with the Sparco wheel, or no because the Sparco wheel is a 6 bolt vs. Grant 5 bolt?
      TIA!
      Dec 2008
      Detroit
      My best guess would be that the part you listed 68-82 would work. Momo has one hub that works for 69-82, I'm pretty sure Sparco is similar. I would buy the Sparco HUB
      Chris--
      Oct 2014
      Here are the two Sparco hubs...
      The first one is supposedly for "Chevy Car". Would someone please confirm that's the correct one for my Nova column?
      Many thanks!
      Oct 2014
      Thanks for the input... The Sparco instructions were horrendous, but I figured it out... Also, would be happy to hear how to change the orientation of an uploaded pic...
      Sep 2015
      Rockvale TN
      Common when using a phone...use a pc instead.
      Oct 2014
      This was uploaded from my PC :-/
      Even tried rotating the picture in my photo software to account for the [possible] forum rotation! No dice...
      Oh well!
      Thx!
      Sep 2015
      Rockvale TN
      This was uploaded from my PC :-/Even tried rotating the picture in my photo software to account for the [possible] forum rotation! No dice...Oh well!Thx!
      Just use Window's Photo Viewer, rotate and save...correct every time.
      Oct 2014
      Much better!! Thanks!
      Mar 2014
      Long Beach
      Which hub did you end up using? I like to swap my moto-lita out for a sparco
      Oct 2014
      Here's the Sparco hub info...
      Steering Wheel Hub Adapter: STRWL HUB CHEVY 69>82
      Part #: 01502234CA
      Good luck!
      Jun 2010
      Deployed
      Anyone know the bolt spacing for the DSE wheel? I currently have a hub with a different wheel, would like to just swap the wheel.
      1970 Camaro/DSE build
      Jan 2017
      pickering ontario canada
      Beautiful wheel
      1971 chevelle LSA 700hp -
