    Results 1 to 9 of 9
      Feb 2013
      Ft Worth, TX
      Custom Interior for a 1970 Chevelle
      I've been working on building a new interior that I designed for my Chevelle. The center console is designed around the raised driveshaft tunnel I installed and the new dash ties into it. So far I've built part of the skeleton out of 1/4 inch steel rod and built a panel for the gauges. I am kind of at a crossroads for how I want to finish off the parts and I was hoping for some input. For the sides of the console and dash I have been trying to decide whether I want to "skin" the skeleton in sheet metal or fiberglass. I don't have any experience with using fiberglass, bit I'm sure I could teach myself how. I would either paint the sides (if I use sheet metal) or wrap them in leather (I could do this over metal or fiberglass.) What are your thoughts?
      Here are some pictures of the Sketchup model I made what I've done so far:
      1970 Chevelle: 6.0 L96, T56, Strange 9 Inch, Ridetech Coilovers, Wilwood brakes
      1978 Firebird: 6.0 LQ4, T56
      2007 Sierra 2500HD LBZ
      May 2010
      kitchener,Ontario,Canada
      I'd like to see some pictures of those gto seats mounted,factory gto mounts or Chevelle?..what about wrapping the console in carbon fiber
      Feb 2013
      Ft Worth, TX
      I used the GTO tracks and welded tabs to them to bolt to the floor. I had to do a couple modifications to the floor pan to get them to sit as low as possible. When I pull the interior apart next week I can try and get a couple pictures.
      I'm not really going for the carbon fiber look in the interior. I'm trying to stick with leather, painted metal, and brushed aluminum.
      Nov 2013
      I have been kicking around the same idea for my 2nd gen Camaro. I am gonna keep an eye on your thread, my idea was to use expanding foam inside my metal skeleton so I can get the contours I am looking for, and then wrap in leather, or fiberglass. I love your design, and cant wait to see the finished product.
      Good luck with the build.
      May 2010
      Awesome thanks for the seat info...feel free to pm me any info and pictures, like I said I am going to be crossing that bridge real soon and was thinking about dropping the floor pans down but, now I will wait to see how you've done it
      Thanks Ryan Austin
      Feb 2013
      Ft Worth, TX
      I decided I would go ahead and use sheet metal for it's simplicity and the fact that I can just paint it if I want to. I added a bar that follows the curve of the windshield and started on the passenger side of the dash which will contain the glove box. I also added kick/knee panels (not sure what to call them.) The driver’s side has a removable access panel like the factory dash has. The place I get sheet metal from only has 18 gauge so all of the interior panels I build will be quite sturdy (and heavy, unfortunately.)
      Feb 2013
      Ft Worth, TX
      That’s about as far as I could get with the dash until I decide what air vents I am going to use. I am leaning towards the round vents found in newer F-150s. At that point, I started on the console. I based the front of the console off of the setup from a Subaru Legacy. That’s the car the parking brake handle is from, so using the console deign means the handle will fit like it should. I made a cardboard template for the front insert and used that to build the real metal one. I also skinned the sides of the console with the 18 gauge sheet metal.
      Feb 2013
      Ft Worth, TX
      Here are some pictures of how I mounted the seats:
      I basically cut off and rotated one of the rear "feet" 90 degrees so that it would be parallel with the floor and on the other side, I think I just cut off whatever was there and made my own mount. It's been so long that I don't really remember how the seat mounts were originally.
      Aug 2012
      Ft Worth TX
      your doing a great job on the design follow thru. fab skills/patience are much better than mine.
      Protouring Texas builds
      78' K5 5.3/ 4L60E-Bdydrptk5-
      71' Chevelle 6.0 LSx,Magnuson,T56 -
      70' Chevelle "Evil Annie" Lsx/6L90/Turbo-
      70' Lemans Sport Wagon 400/400 Poncho power
      Facebook- Protouringtexasdotcom
      Instagram- @Protouringtexas
