View Full Version : Manual Transmissions
Pages :
1
2
3]
4
5
6
7
8
9
10
11
- TKO600 Mockup
- mechanical clutch inkage with a 5 or 6 speed?
- Mech. Vs. Hyd. Clutch
- mcleod t56 for older cars?
- T56 question about clutch stuff
- Please Help!!!
- th350 to richmond?,69 camaro
- t56 reverse lockout solenoid
- Consider this Richmond 5 speed, or wait for a TKO600
- T56 behind 383, confused
- Transmission rebuilders recommendations
- engineering test reports
- LS1 T56 behind Pontiac block???
- Need input from t56 owners
- M12 T56 issues
- t56 questions, which parts would be best for my needs?
- 4 speed rebuilders locally FL
- t56 questions????
- Ok.. of all the clutch recommendations...
- LS1 T56 Clutch question
- Automatic to Manual Conversion in '77 Firebird
- T56 - Tr6060
- How to tell diff between lt1 and ls1 T56 and options for no 5th gear...
- Anybody run a manual trans with BIG power??
- Tremec 3550/TKO measurement
- Moving T-56 shifter forward
- Need T56 info - fast
- best place to buy tko 600
- T56 hydraulic line question
- Tremec TKO behind a Gen3. Pilot bearing question.
- Second/Third shift-Muncie shifter rods jam
- LT1 Starter for T-56, help needed
- m21 clutch/fw recommendations..
- t56 hydraulic clutch
- t56 plus big block. what flywheel?
- which Hyd throwout bearing to use?
- are viper and viper truck trannys the same?
- McLeod bellhousing/tranny tunnel clearance issues
- T56 to T10 bell housing
- Newb has some questions
- 5 or 6 speed
- Trying to take my T56 out of my 1st gen right now!
- hydraulic clutch
- Does anyone make a custom crossmember for a Muncie
- engine removal for tko600 and hydraulic clutch?
- 1st GEN WITH LS1/T56/12 BOLT DRIVESHAFT LENGTH???
- t56 in '74 Nova?
- T-56 tail and bellhousing measurements
- It's Here - I wonder how much$$
- TKO 500 and Autometer speedo?
- Low Buck T56 swap(Tyler from ATS & all who can help)
- please tell me i didnt screw up....
- ssr t56 6 speed?
- Will i need ...???
- TKO 600 in a G-body - Tips
- ATS master cylinder bracket for 2nd gen
- composite pilot bushing?
- OEM vs. Aftermarket Hydraulic TO Bearing
- Drivetrain vibration, wrong slip yoke?
- LS1 F Body GM Part Number
- 68 Mustang Hyd clutch?
- 66 Mustang Toploader sliding out of 3rd gear
- Firewall re-enforcement for clutch master
- clutch fork boot
- Shifter Boot
- MT Shifter Boot/Bezel for Monte SS available
- Dirt cheap auto-manual swap in a 3rd gen?
- pilot bushing install questions?
- Cheap 5 speed?
- Looky at all dem gears!
- Grease pilot bearing?
- Do I need an upgraded shift fork for my T56?
- VW Transmission Gear Help needed
- Need Mcloud Bellhousing Help!!!
- Muncie M21 in 1962 Impala
- May 2007 CHP: LS2 w/ tremec
- pushrod travel
- 6-speed question
- What flywheel with 396 and 6 speed? (Need help bad!!!)
- Switching from auto to TKO600
- TKO Install Question
- T56 into a 65 Chevelle
- Richmond 5-speed w/OD, 600-ft/lbs
- nova 6 speed!.....finally!! shifter?
- Please help with T56 problem
- Which manual trans really works?
- Can I spray out of the hole on a stock 6 speed?
- TKO600 hitting the floor and bellhousing wont fit
- Clutch manuf. quality
- Liberty Gears
- kiesler 5 sp install on 69 Camaro?
- Transmission/Axle ratio question.
- 6 Speed Wiring??
- T-56 To BBC
- viper T56 to 6.1 hemi
- t56 in a 67 GTO (A Body)
- Ats Crossmember ??
- Muncie Linkage needed
- flywheel:stock or performance
- T56 Shifter Knob Thread Size?
- T56 install help
- ZF 6 speed question
- Holes in bellhousing
- TKO600 is alot of fun
- Ecotec to Super T10 4 Spd
- Info on hydraulic throwout?
- Muncie 4 spd Lubricant
- Which clutch for TKO?
- bad vibration with new t56
- Ecotec and the 5 speed that comes with it - questions
- Sorry
- T56- Adaptor plate and mechanical linkage, or Hydraulic setup?
- Tko600 What Fluid Options Can Be Used
- Need help installing TKO
- vss sensor
- Bummed I cant use 6th gear legally
- Still have the vibration....
- Need some input.
- T56 to a 455 Olds
- t56 rebuild kits
- Med-light duty AWD 5spd w/passenger-side front output
- T-56 flywheel
- D&D T56 close or wide?
- LT1 and LS1 T56???
- console for 1st gen T56 install?
- 69 Camaro with lt1 and t56 help????
- Nova T-56 Questions
- Bell housing bolts
- LT1 T-56 in 70 Chevelle, HELP!
- 1 year old TKO600 leaking at input shaft seal?
- Richmond 5-speed
- Muncie vs. TKO 600
- Caddy CTS-V 6-speed Trans???
- tranny identification
- Muncie Code Decode Please!!
- Ok new build and I'm lost.....
- will this work?
- T-5 grinding problems
- Forte's Parts Connection
- Tri-Five Five Speed
- master cylinder question
- big block swap
- Quatermaster Clutch
- Classic Mopar 5 Speed
- TKO speedo cable?
- t56 popping out of reverse???????
- locked up muncie
- best rear gear with T-56
- Clutch Fluid Reservoir Options......
- What does it take to get a T56 into a 71 Chevelle?
- no hole for clutch pivot ball
- How strong is a T-5?
- Nobody laugh....performance parts for a 4-spd Saginaw?
- Muncie Question
- What is this hellacious noise???????
- TKO 600 issues....
- Part number for 2 pc main seal t56 flywheel?
- TKO 600 gear help
- T56 speedometer
- 12 inch clutch and GM hydraulics
- The torque rating on a TKO600
- Holy sh*t--dexron-III vs gm synch in a TKO
- Bellhousing Alignment Tool
- whats everyone using for a clutch pedal stop?
- TKO length vs. Muncie
- T56 Differences...
- richmond six speed !!!!?????
- TKO600 Throwout Bearing????
- Aftermarket T56 - Which Hyd. T/O bearing and M/C did you use?
- 55 chevy 5 speed
- M22 4 speed
- General external slave hydraulic clutch question
- auto to manual swap
- T-56 Good Deal?
- LS1 To TKO500
- T-56 clutch line help
- Chevy viper t56 in 69 camaro
- Which T56 is it?
- Mechanical vs. Hydraulic clutch linkage
- whats everyone with TKO's runing for a bell housing?
- M22 conversion (from TH350)
- T56 Yoke install
- BBC T56 Help Needed!
- TKO600 or T-56
- 78-87 regal auto to manual?
- Feedback on the Richmond OD tranny?
- New Bellhousing?
- Muncie on a later SBC
- help, custom clutch?
- Looking To Put A 5-speeed In My 67 Nova
- 66 Gto
- Retrofitting ls1/t56 into 69 camaro; clutch ?
- T56 will not go into reverse, help please..
- What do I need to put an LS1 style T56 behind a BBC?
- Classic Chevy 5-Speed group purchase
- Need Help: Viper transmission value
- T56 Clutch Fork Issue
- What lakewood scattershield part #??????
- Is it worth it?
- differences in the Tremec TKO
- faceplating
- Clutch recommendations
- Viper T56 fitment
- LT1 T56 hydraulic lines
- t-56 shifter questions
- What do I do about a scatter shield for an LT1 T56?
- Need Flywheel & Clutch Recommendation
- T56 swap into a 69' Camaro
- Hyd. Clutch for TKO
- Quick One: LT1 T-56 will Viper gears swap
- GM/Viper T56 Owners, What Shifter do you have?
- Price on used T56
- HELP-Mcleod adjustable pivot ball question
- Clutch question
- Are all short throw shifters equal?
- 1 pc vs. 2 pc T56 problem
- TKO600 - Anyone NOT have to scalp tunnel?
- Do Hyd TO Bearings Leak?
- Identifying T56 by numbers => Who know?
- LT1 to LS1 T56
- Run-Out Vs. TIR; bellhousing alignment
- I broke my TKO 500...
- TKO 600 factoty shifter
- Good tech guide for TKO Install in 65 Mustang?
- What will I need to install TKO IN 65 MUSTANG?
- strongest manual overdrive gear box around
- T-5 Manual Transmission
- TKO Bolt Size Question
- High Output Turbos & Manual Box
- Shifter Stick Bolt Hole Specs
- TKO 600 and gear choice
- TKO 500 and 3.55 Gears
- 04 Gto Trans Strengh?
- Someone PLEASE ID this TOPLOADER 4 SPEED?
- which stock flywheel??
- TKO Owners- Shift lever?
- Classic Chevy 5-Speed is aquired by B&M Racing
- Stuck in gear..
- tko 600 strength
- IMAGINE Junkyard Mopar, AMC, ECOTEC, 4200, Northstar 5-speed!
- Hard Shifting TKO-600
- Whining t56
- TKO600 + turbo = ?????????
- removing the t56
- Muncie M-21 Question
- hydraulic throw out bearing set up
- TKO-600 owners
- T-56 Oldsmobile Pilot bushing
- t56 in 79z
- Putting a T56 Behind a Poncho 400/455
