    Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 41 to 60 of 115
    1. #41
      Jul 2020
      I have to say, that with all the issues I was having with my 1965 Mustang, I was ready to sell it. Out of desperation, I reached out to him on the Holley forums website for help not even aware that Andrew did tuning.
      Andrew not only fixed all the issues with my tune, he gave me great advice to re-architect my electrical system to fix a nasty ignition misfire. I also liked that he showed me what he did to the tune so I can make changes in the future rather than rely on others to do it for me. His time was probably the best money I've spent on that car.
      I can't recommend Andrew enough.
      -Shannon
    2. #42
      Quote Originally Posted by LastDeadLast View Post
      -Shannon
      Thank you Shannon!
      Instagram @projectgattago
      Dr. EFI
    3. #43
      One of my customers was having some cooling issues, so I suggested using one of the new OEM brushless style SPAL fans. There are a couple of versions that fit many classic style radiators, but we settled on the C7 Corvette fan. It is rated at 600 watts and is an absolute beast. The issue with these fans is that they have a built in speed controller, and can't just be turned on with a simple relay.
      The great part is that the Holley EFI systems (excluding Sniper) can output a signal that will allow these fans to operate at variable speed, based on engine temperature. It is also possible to integrate the AC into the fan control strategy and have fan speed settings for when the AC is on and when the AC is off. The other great part is that the C7 fan can be purchase new for about $200-$250 from various sources. This is a bargain, considering that the fan has a very powerful motor and has a built in controller.
      So if you are starting from scratch, definitely consider one of these fans and a Holley EFI system, because ultimately the combination might cost less than other options.
      Dr. EFI
    4. #44
      Nov 2010
      orlando fl
      Are there any services you can provide from out of state?
    5. #45
      Quote Originally Posted by yellow1098Greg View Post
      He does everything remote from out of state... and is Holley EFI trained/certified. You won't find anyone better, more knowledgeable, nor willing to help than Andrew!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
    6. #46
      Greg, I have customers all over the country. Please don't hesitate to get in touch.
      Quote Originally Posted by OLDFLM View Post
      Thanks Ty! Appreciate the kind words.
      Dr. EFI
    7. #47
      Feb 2019
      Kankakee IL
      You forgot sexy.
      Tracey
    8. #48
      Quote Originally Posted by tsaints1115 View Post
      you forgot sexy.
      ;-p
      Dr. EFI
    9. #49
      Apr 2010
      Portland, OR
      Andrew is amazing, really seems to enjoy talking cars and helping out!!
      1973 Firebird 466 Pontiac, T56, C5 Brakes, PTFB and Hotchkis suspension
      2011 Camaro SS Supercharged, ZL1 body and brakes, Z28 suspension.
    10. #50
      El Paso, Texas
      I haven't used his tuning services but I follow Andrew on these forums and the Holley ones and he's always a great source of information. I'll be contacting you for a couple of remote tunes on an LS1 and an LS3, if I can ever finish them lol. BTW got anything on controlling the newer GM alternators? I saw Tick is working on a box but if I can run it off the Terminator X, that would be great.
      Alex
    11. #51
      Quote Originally Posted by CapSS92 View Post
      Alex
      Thanks for the kind words Alex. I believe there have been some threads on the Holley EFI forum about the pwm controlled alternators. I don't have experience, yet, but I'm sure it can be done. The down side is that you will use up one of the precious 4 outputs on the TerminatorX.
      Dr. EFI
    12. #52
      The C7 Corvette engine fan combined with the Holley system has me intrigued. Are there any threads with more info? I'm not having any luck searching the forum. I'm a long way off from engine tuning, but I plan to use a Sniper EFI and ignition system on my Pontiac motor. I'll keep you in mind when the time comes!
    13. #53
      Quote Originally Posted by Stupidnewbie View Post
      Unfortunately, the Sniper does not have the required pwm- output as an option. If you have not purchased a system yet, I would highly recommend going with the new Terminator X Stealth. It uses the Terminator X ECU, which does have the PWM- output available. Better still, do a multi-point system using an Edelbrock EFI intake, couple that with a dual-synch distributor, and Terminator X ECU, and have a fully sequential system on your Pontiac engine.
      Dr. EFI
    14. #54
      Big announcement from Holley yesterday!
      Dr. EFI
    15. #55
      You warned me this would happen!
    16. #56
      "That, Mr. Anderson, is the sound of inevitability..."
      ~~Agent Smith
      Dr. EFI
    17. #57
      Oct 2005
      Olathe, KS
      Do you have any interest in trying to figure out a driveability issue on a small-block with an Edelbrock TBI system? I'm in the KC metro.
    18. #58
      Quote Originally Posted by Chrisbequick View Post
      Since you are local, I would be willing to give it a shot. Sending a PM.
      Dr. EFI
    19. #59
      Really excited to be working with Herb on his Chevelle V2.0. Check out his build thread here:
      https://www.pro-touring.com/threads/127424-Chevelle-2-0
      I did a little idle tuning on it last week, and it sounds amazing!
      Dr. EFI
    20. #60
      Feb 2007
      Tinley Park, IL
      Andrew, do you have the pins/plugs necessary to shorten the universal harness that come with the Sniper, to a specified length?
      Nick ~
      1969 Cutlass
