    Results 1 to 20 of 20
      No. Nevada
      Deleting the distributor for crank fire SBC?
      Looks like I've finally found an inexpensive MS3 control and timing wheel to complete my partial Edelbrock EFI system.
      Recently taken off the sellers SBC 350 and worked fine.
      I will want to eliminate the distributor but will also still need to drive the oil pump.
      This seems like a question that should have already been answered many times but my searches are not getting me anywhere useful.
      Going into my flatbed support/tow truck as I want better performance at high altitude than a carb can give me.
      Truck runs great at low altitude but stinks going over the passes, runs fair at my home elevation of 4700'.
      With this done a low boost supercharger becomes more practical idea down the road.
      At these prices I want my gas 100 octane, leaded, and my windshield washed!
      May 2011
      Chippewa Falls, WI
      Vortec 350 distributor, and EFI connection has a alum cap for it. You can use the cam signal off the pickup on the distributor, and then run the crank signal off the crank wheel. I don't know of any other way to drive the oil pump without some type of distributor in there.
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
      Loganville, GA
      The 92-97 LT1 engines had an oil pump drive that looks like the bottom part of a regular distributor. It may be possible to adapt it. You can see it here on this page, very bottom right image: http://www.ellweinengines.com/ESE31/ESE31.htm
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      No. Nevada
      Looked up the LT1 drive.
      Seems some folk have problems with them and a hassle to mount in my Gen 1 block.
      I think I'm going to cut down an old distributor body and shaft, then make an aluminum cover for the stub.
      Also on-line I see pics of a 350 Vortec "Distributor" that does not have a regular cap, just a cover and an output to a cam sensor?
      Might be handy to have a specific year and model that those came in to see if one could be found on the cheap.
      Not having good luck with a web search.
      May 2011
      Chippewa Falls, WI
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1981 Jeep CJ7
      No. Nevada
      I guess that once the MS3 gets here I will be able to see if a cam sensor makes sense or is not really needed.
      I do appreciate the suggestions, searching for distributor delete and similar was getting me nowhere.
      Sep 2014
      You will need a cam sensor to run sequential spark and or timed injection.
      Fredericksburg, VA.
      This seems like a lot of work to me. If you are looking for performance over a range of altitudes, wouldn't it just be simpler to install one of the many new aftermarket throttle body EFI units? I installed the MSD Atomic TB EFI and it works good going from a low altitude to a high altitude. The New FITech throttle body units can be purchased for less than $1,000. All of these EFI systems monitor and adjust the AFR as altitude changes. If you are worried about spark scatter caused by oil pump vibration when using a conventional distributor, Melling has released their "Sharktooth" series of oil pumps which use helical cut gears rather than straight cut teeth which dramatically reduces the oil pump vibration level.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jonesboro, Arkansas
      Hey Steve,
      I think you answered my question on the other thread, lol
      Carl Wilson
      Jun 2010
      Deployed
      Seems like your ready for a modern engine
      1970 Camaro/DSE build
      Lawrenceburg, TN
      May 2015
      Island Lake, IL
      What's considered modern about newer style pushrod v8's?
      High horsepower builds end up using forward facing cam-mounted distributors and 4 magnet crank triggers. Dart LS Next engine blocks end up using traditional (not standard ls) style main caps for the crankshaft. GM uses Holley HP EFI for the Chevy COPO Camaro. 2016 Mustang Cobra Jet uses a GM TH400 based transmission.
      Jun 2010
      Deployed
      Modern engines are not using distributors. They are using computers to fire off coils based on the crank trigger. Just because you can buy and use "newer" styles of the old technology doesn't really make it modern....it's still old technology. Modern is computer controlled sensor monitored.
      I was referring to an LS engine. Sound like that's exactly what he's looking for.
      May 2015
      Island Lake, IL
      Modern engines are not using distributors. They are using computers to fire off coils based on the crank trigger. Just because you can buy and use "newer" styles of the old technology doesn't really make it modern. Modern is computer controlled sensor monitored.
      You totally missed the point but for your sake I will agree that newer engines use computers.
      Jun 2010
      Deployed
      Quote Originally Posted by F-Body International View Post
      No I didn't miss the point you were trying to be a smart a$$. I get you were taking a stab that an LS is still a push rod engine, but how is that relevant? Guy doesn't want a distributer and trying to make it like a modern production engine...so it sounds like its a better idea to get an LS then try to make a SBC operate like an LS.
      May 2015
      Island Lake, IL
      First off, you're the one sweeping into an SBC thread saying how the LS engine is better. Distributors become cam sensors (like an LS has) when converting distributor based engines to sequential efi. Wasted spark engines which fire on both the compression and exhaust stroke don't need distributors but they do need and oil pump drive. A better idea for me would be to use the architecture your car was designed for and make it better. An LS engine isn't that much lighter than a small block Chevy. Both LS and SBC can be had in aluminum block form. One of the strongest LS engine blocks (Dart LS Next) even uses traditional style 4 bolt main caps like we find in SBC and BBC engines. I don't hate LS engines. They're badass but to sweep in with "newer=better" comments like that is aggravating for me. Like I mentioned earlier, both cases are pushrod 2 valve v8 engines.
      Jun 2010
      Deployed
      I didn't say one was better. I pointed out what he was looking for sounds like a modern FI engine.
      No. Nevada
      Well it seems the seller misplaced the MS3 so I only got the crank trigger and some other small parts.
      I have no desire for an LS, just want to improve performance of the 350 I have using an incomplete Edelbrock FI unit I got cheap.
      Back-burner at the moment as it seems I need to replace my CNC mill.
      No. Nevada
      Wow, time sure flies when you are not having fun.
      Been busy with "Life" issues, little things like closing a business, moving, and having to put up a new workshop.
      Finally getting back to actually working on cars again.
      The MS3/distributorless question has moved to a more interesting build than my truck.
      The MS3 unit itself eventually showed up, after I sold the injection system I was going to use it with.
      Now looking to use it for ignition only on my 327 '68 El Camino build.
      Induction is 4x 44IDF Webers.
      Cam is probably just a bit too much to be practical so should be just enough fun to get me arrested.
      I need to search this site again for clues regards coils.
      As I recall EDIS packs should work well.
    Tags for this Thread
