    Page 13 of 23 FirstFirst ... 3 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
    Results 241 to 260 of 441
    1. #241
      Sep 2011
      Southern Ontario
      You have enough clearance to the wheel well when bottoming out? I love this truck!
    2. #242
      Nov 2010
      We'll see, I can raise it if I have to.
    3. #243
      Nov 2010
      Work on the bed is progressing. I had to cut out the recess area for the license plate in the rear pan. The plate goes in the bumper so I won't be needing it and it was hitting the rear crossmember I welded in to protect the gas tank. Unfortunately I had to remove the tailgate to get at the rear pan, in doing so, all the bondo that was packed into the rust hole began to fall out, so now I have to rebuild the bed corner. Opened up a "Can of Worms"
    4. #244
      Nov 2010
      Finished rebuilding the bed corner, it took 5 different pieces of sheet metal to get all the structure back .
    5. #245
      Nice! no one would ever know it was there.
    6. #246
      OMG how I LOVE this build!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
    7. #247
      Nov 2010
      Thanks Wayne, I actually sanded through some of the paint, to make it look like it belonged there..
      Quote Originally Posted by OLDFLM View Post
      Thanks OldFlm
    8. #248
      Nov 2010
      Moving on to the wheel tubs. One done, second one almost done, should finish up tonight...
    9. #249
      Nov 2010
      Wheel tubs are done, got the hole cut for the gas tank filler, just have to machine a bezel to clean up the hole..
      Name:  Gas Filler Bezel.jpg
    10. #250
      Nov 2010
      It's Hump Day! Got my axle cover welded in. I had ordered a cover online, but it came in made out of 18Ga. sheet metal, kinda flimsy. So I went to my local sheet metal shop and had one bent up out of 14Ga. same as the floor. Also decided to 3D print the bezel for around the filler neck, then welded a steel ring to the floor to bolt it to.
    11. #251
      Looking good.
    12. #252
      Nov 2010
      Slow progress, Working on my tonneau cover, frame is done, I plan on bonding on 20ga. sheet metal on top. All I need to do is figure out a hinge mechanism. Also go the exhaust finished..
    13. #253
      Jan 2011
      Jefferson City, MO
      Looking good! Will you add a bezel around the exhaust tip? I don't know it there's enough heat to compromise the paint.
    14. #254
      Nov 2010
      Quote Originally Posted by Peanut1959 View Post
      I might, but honestly not to worried about the paint.....
    15. #255
      Jan 2016
      Chino Valley, AZ
      i love the exhaust! nice work.
      84 Ford LTD Wagon
      05 Ford Excursion
      Instagram
    16. #256
      I like the way the exhaust comes through the bed, nice work.
    17. #257
      Nov 2010
      Quote Originally Posted by frink84 View Post
      Thanks guy's.
    18. #258
      Feb 2019
      Ive been watching this for awhile. Finally joined the forum. I love the truck.
    19. #259
      Oct 2018
      Phoenix, AZ
      Out of curiosity, did you support the exhaust behind the body where it exits? I want to do the same thing, but I'm worried it will rattle over bumps. That would drive me nuts.
    20. #260
      Nov 2010
      I have to figure out something....
