    Results 1 to 11 of 11
      Jun 2018
      Alamo, CA USA
      Components to mate an LS427/570 and T56...
      Ordering an LS427/570 and T56 tomorrow. The plan is track days and daily driven.
      What would you guys recommend in terms of the flywheel, clutch, and bell housing?
      1973 Camaro: LS427/570, T56, Speedtech ExtReme subframe/torque arm
      NJ
      If you're purchasing the Connect and Cruise package like you've mentioned in other posts, it will have everything you need to mate the two together.
      Jun 2018
      Alamo, CA USA
      Quote Originally Posted by John McIntire View Post
      GM isn't offering a C&C package on the LS427/570 yet, so I know I'm going to be missing something to mate those two together.
      NJ
      Quote Originally Posted by roguegeek View Post
      If that's the case, I'd just get the LS7 from Pace and give Craig at Bowler a call for the rest.
      Jun 2018
      Alamo, CA USA
      I'm not quite sure where the disconnect is here, but that's not my question. I've already decided on motor and trans as well as where I'm purchasing from.
      You need a flywheel and clutch, as well as a bell housing. You will also need a hydraulic TOB and the hydraulic MC at the clutch pedal.
      Instagram @projectgattago
      Dr. EFI
      Jun 2018
      Alamo, CA USA
      Thank you. Are there any recommendations out there for a flywheel, clutch, and bell housing?
      Nov 2016
      Sulphur, La
      I'm following along here. I am interested in the same combo and will have the same questions...
      Depends what's important to you. Many people, including me, like the LS7 clutch, however, it is rather heavy. The weight makes it drive nice, but isn't optimal. Same for the bell housing. I like the stock forth gen Camaro bell housing, but others prefer the steel QuickTime.
      Dr. EFI
      Jun 2018
      Alamo, CA USA
      Thank you for your feedback. Since this discussion is getting more specific now with bell housings, I'll make a post on the proper forum to continue.
      Nov 2009
      Austin Texas
      Does that one have a 6 bolt or 8 bolt crank? Im really happy with my Tilton ST-246. It drives very nice and the support from Tilton has been great.
