    Results 1 to 20 of 21
      Houston, TX
      Wilwood Emergency Brake Cable??
      I have installed the Wilwood rear brake kit on my 1969 Camaro. It uses the inside of the rotor as a drum. The stock cables to not match up to the kit. Is there a way to use the stock cables?
      I have heard Lokar makes a cable that will work. They are $90 from Summit.
      Aug 2005
      phillip, im getting ready to put the same kit in my 69 camaro. let me know what you find for cables. i recieved the brake kit yesterday, do your calipers look like the ones in the brochure? mine look like a different style and are not shiny. thanks, greg [email protected]
      Houston, TX
      I had my calipers powder coated red. I have not tried to install the cables yet. I am still waiting on parts from Precision Brake (a month and half later) (Long story). They are alot different than the stock cables, but I think they will work a lot better. With these cables, I believe I can eliminate the big "X" under the car and the cables that rub the exhaust.
      SouthTX
      I was told the cables from Lokar are from a Ford Explorer application. You will just need to buy the clevis bracket.
      Houston, TX
      They are for a Ford Explorer. Can you just order the ends? The ends that they sent with the kit thread through. The stock cables can't thread through unless you cut a slit in the connector. I will call Lokar today.
      Phillip
      Houston, TX
      I talked to Lokar. You can do it with just the connectors if you slit them. The part number is EC-81FC and they are ~$30 from Summit. Since I already have the cable kit, I am going to use it. The kit will allow me to run both lines down on side and clean up the bottom. I have never liked the way the cables rub on the exhaust.
      I can't find the cable kit I purchase on Summit. It was $85. Now all I find is a $132 kit.
      Phillip
      SouthTX
      Yes, the connector is referred to as the clevis bracket?
      Amsterdam,The Netherlands
      Country Flag: Netherlands
      Quote Originally Posted by Phillip_L
      Phillip
      Philip_L
      Do you have the part# from the Lokar cable kit?
      Cliff
      Sep 2001
      Pasadena, Ca.
      I suggest calling Lokar for the part numbers.
      I have the same setup, and when I called they had a few options ( braided, plain etc.) I cant remember what part # they were, but they were listed all wrong on the jegs site at the time. I ordered the parts by phone to be sure the right #'s got here. it looks like I have to fab up a little mount at the pedal, but the rest of the cables fit great, and look a million times cleaner than the stock setup.
      Steve N
      69 Camaro RS, LT1/T56, Chassisworks front clip,Fab 9 rear. DSE deep tubs. 18x9 & 18x12 Welds, 265 & 335 Pilots
      Video clip http://www.youtube.com/watch?v=3NGU0o7oJzE
      Lokar hand brake install kit?
      Saw this thread and thought I'd ask this question: A quote from ZZ Top in 2002 said that a member here "(Tito) makes a kit to really help stiffen the mounting (of a Lokar hand brake) in a clean way." ANyone know any more about this kit? Is Tito still around?
      Thanks!
      Hans
      Oct 2003
      South Lyon, MI
      I have been following the tread, but not clear on what is discussed about the cables. Are we talking about using the stock camaro parking brake mech. with different cables to eliminate them from hanging down (or against the exhaust)?
      I have a 69 camaro w/Baer brakes and mini tub. I would like to use the stock parking brake lever, but don't want the cables hanging down.
      thanks,
      Kevin
      69 Camaro LT4 T56 9" Budnik Hammer Baer Vintage Air DSE stuff mini tubbed......
      I am struggling with this Wilwwod ebrake install on mt 67 camaro, I would really appreciate it if someone could post pics of their install with the factory footbrake setup.
      Last edited by ertoys; 12-17-2005 at 11:43 AM. Reason: Did not choose email notification
      NYC
      Hey guys maybe you can help out here,i got a `70 camaro and have the Wilwood rear disc set up with the drum style e-brake,my problem is that with the staggered shock set up i cannot clear the caliper to fit on the drivers side cause it hits the shock and shock mount,what did you guys do to solve this issue?any help appreciated.
      George
      `67 Buick GS 400 Hdtp,494ci Stage 2 BBB,5-speed TKO-600,"The Black Widow"
      Fontana, CA
      Drum style e-brake . . . the guys at Currie told me to swap sides and installl 'em backwards. That is how they did it. That is all I know.
      I have the same fitment issue with my spot style e-brabke. It doesn't clear the driver side shock.
      Nick R.
      Central Texas
      Did a search for Wilwood e-brake cables. This post came up, kind of old but does anyone have any current info or pictures. I have Wilwood disc brakes with internal drum E-brakes. I am working an my Chevelle and using the factory foot pedal. Looks like I will need to use a combination of factory cables and Lokar cables and custom brackets and mounts. From what I can tell it looks like the best solution is to do away with the cloths line factory set up and run the cables straight down the drivers side. If anyone has been down this road , I would really appreciate any help you can provide.
      Aug 2003
      You have it exactly right KMD. Bring the pass cable over the rear to the dirers side, and tie into the factory front cable on the drivers side rail
      Houston, TX
      I used this kit:
      http://www.summitracing.com/parts/LOK-EC-81FU/
      I went down the drivers side like you said.
      Phillip Lawrence
      1969 Camaro
      LS2 with a Kenne Bell
      Central Texas
      Quote Originally Posted by Phillip_L View Post
      I used this kit:
      This is the same cable kit Lokar suggested. I guess a bracket will need to be made to hook the cables to the front original cable with all thread at the end. Then you could make adjustment. I am a bit confused on how the Lokar cables will hook to the original frame brackets on the frame. For example: Originally my Chevelle E-brakes hooked to the brakes themselfs and then went to a bracket on the frame. Then they went to the front cables from there. Can you still utilize this e-brake cable frame mount with these cables?
      Hope that makes since...
      Houston, TX
      Lokar sends you everything you need. I will see if I can get a picture. The only thing you have to figure out is how to connect your e-brake cable to the brass block (they will send) that holds both rear cables. My e-brake cable is threaded. I just put a nut on each side of the block and it was connected.
      Phillip Lawrence
      1969 Camaro
      Oct 2012
      Hello guys,
      New to the site . . . . I'm currently working on putting my car back together. I'm on a major budget so I have to do things myself (Besides it being fun too). I'm attempting to build my own exhaust but I've run into the e-brake cable meeting the exhaust.
      Could any of you please post photos of your results and or explanations, (I'm a visual person).
      Thanks Guys and Love the WebSite ! ! !
