Results 1 to 20 of 20
Thread: 60 to zero braking distance
08-23-2005 #1
Anyone got the data? I used my g-tech Pro RR, my b-body 12" front discs with Wilwood GMiii calipers and t/a rear disc 71 camaro stops in 165-170' with Hawk HP plus pads. Not all that steller. If pushed harder I may get the stops shorter. I use a dual diaphram booster and 1 1/8" master with adjustable prop valve. The G-tech is consistant. I can creat graphs and overlay runs. They have been near identical. With sticky Kuhmo tires I can't lock the wheels. So what are your numbers?
08-23-2005 #2
New to Pro-Touring
- Jul 2005
- 14
that's not ground breaking braking performance, but it's a pretty heavy car, and those big GM calipers are know for lots of flex. First thing I'd look for is if you've got enough pressure at the caliper. You should have 800-1000 psi. Usually the culprit is low vacuum, 18" of manifold vacuum are required to run that booster, regardless of what the booster salesman says.
08-23-2005 #3
