      Apr 2004
      Cedar Rapids, IA
      stripped swaybar bolt
      I have been reading up on what others have done to repair stripped out sway bar bolts in GM frames. I have a stock 64 A-body car that I would like to put a SC&C swaybars and springs in the future.
      For now I'm considering either a nutsert or taping out the 3/8 to 5/16.
      Like to hear what other have done.
      Central CA USA
      The frame metal is swaged up to form a tube like protrusion inside the frame. I doubt there will be much left of it if drilled to 3/8". I'd do nut-serts, or place a nut plate inside the frame. I like to use 3/8" header bolts, but they need to be long like big block bolts.
      Maine
      I had to do a quick fix on mine once and it has held together since - I filed-out the rough inside of the hole with a round file. Then, I welded a nut onto a washer, and welded a little (maybe 3'' long) tab of 1/8'' plate onto the end of the washer so that I could use my fingers (holding onto the tab) to slide it into place over the hole. Put the bolt in and the tab kept the nut from spinning inside the frame. Got back on the street quick.
      If I had a weld-on nut insert in the toolbox at the time, I probably would have used that. But, I was in a rush.
      John
      Midwest
      We usually weld nuts into the frame when possible.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Apr 2004
      Cedar Rapids, IA
      Quote Originally Posted by oestek View Post
      Looks like you Tig Welded it? Looks very nice.
      I got some 5/16 nutserts to shadtree style fix for mine for now. Calls for 17/32 (.531) bit size. Guess I will need to special order that in now.
      Jun 2008
      Greenwood, Indiana
      I just did this repair. When mine stripped i found out that the frame in that area was rusted on the inside so I made a new plate with nuts welded to the back side of it. I then cut out the bad section and welded the new plate in its place.
