    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 109
      Oct 2009
      San Diego, CA
      Moved here for Matt's sake
      Nov 2012
      Sacramento, CA
      This post topic moved to another thread here.
      Oct 2009
      San Diego, CA
      Aug 2012
      Peoria, AZ
      All I need now is for Ron to explain "wedge" and I'll have everything I need to go NASCAR racing... ;)
      Seriously, does anyone else feel like they are stealing by reading all of this information here on a free public forum?
      Props to you Ron!
      Lance
      Nov 2012
      Sacramento, CA
      Props to you Ron!
      I'm taking a little time off from racing ... before I tackle my next project ... and I enjoy sharing & helping if someone is actually going to use it.
      Were you serious on the"wedge" question ... or just being funny?
      Jan 2009
      Hey Ron, I have another round of questions for you.
      After giving your opinion of what would be a close to optimal setup, I was a little curious about your opinion about how much spring is needed to support the weight of a car. Do you like pre-load on springs, or not. What effect does it have? If you wouldn't mind elaborating a little bit more, I'm sure it could benefit us all.
      The reason I ask is because you recommended 450lb springs up front, and 250lb springs out back. The front springs and .250" sway bar with my current setup have not been able to control the roll to a degree that I've been happy with, and tend to settle so much that I would need to run a longer spring than I can fit on the coilover without compressing the longer spring to get in under the shock collar.
      Matt
      Nov 2012
      Sacramento, CA
      Matt, I need some more clarity,
      I'm NOT clear on what you're asking. Can you re-phrase this?
      Until I read further down, this question confused me more ... because all springs are preloaded with the weight of the car.
      Again, all springs get preloaded with the car's weight & I'm not clear on what you're asking. Are you asking ... is there a problem with running a spring that has to be compressed to install it on the shock? or ... ?
      OK. Let's discuss higher rate sway bars & springs. But I need your shock mounting motion ratio & shock angles to do this correctly.
      What do you mean settle? "Settle" in spring lingo ... means the springs started out a "X" free height (no load) ... and after being installed and used ... are now a shorter free height when removed. Is that what you mean? Or are you calling the compression of the spring with the car's weight "settling" ... when in fact their free height is the same as before?
      Two things ...
      1. Why would you need to run a longer spring?
      2. When you ran this spring before, did the car sit too low?
      Aug 2012
      Peoria, AZ
      Truthfully I always wondered exactly what the nascar teams were talking about when discussing putting wedge into the car?
      Lance
      Nov 2012
      Sacramento, CA
      Hi Lance,
      "Wedge" is a Stock Car term meaning the same thing as "Cross Weight" used by Road Racers & Open Wheel Racers, even in oval racing. Some racers simply shorten it to "Cross" ... as in "put some cross in the car". Then throw in a mix of Engineers and it's a wonder any of them understand each other.
      I have to go back & forth because I've been involved heavily in different forms of oval & road racing. I find it amusing the terms are so different. One of them you & I have been discussing is KPI & SAI. Stock car guys still use the KPI term, but Double A-arm cars don't have king pins.
      Anyway, let me explain what Wedge & Cross Weight are ...
      If we were going road racing, and the rules allowed, we would be running the car as weight balanced side-to-side as we could get it. Here is a car that weighs 2572#, with a 48.77% front weight & 51.23% rear weight.
      Example #1
      If we could achieve it, the 4 scales would read ....
      LF 626 # RF 626 #
      LR 660 # RR 660 #
      This is a car with no wedge or cross weight.
      Example #2
      If that same car was on the scales & read ...
      LF 616 # RF 636 #
      LR 670 # RR 650 #
      You'll notice the LR & RF corners weigh more than the RR & LF. That is wedge or cross weight. In this example, the front wheels have a 20# difference between them ... as do the rear tires. That's not much, but not optimum. Not counting other aberrations in the suspension, this car would have a little more grip on left hand turns & a little less grip on right hand turns.
      It's not much, but when you're racing and driving the car at 102% & the tires are at their optimum slip angle ... with no room to spare ... 20# would make a small difference that would affect the car "a little" & a talented race driver would feel ... and be whining & screaming for a change.
      OK, just kidding on the whining & screaming ... sorta. You NEED the driver to give accurate, precise, measured feedback in a consistent, methodical way to know when to tune, which direction to go & how much. The difference between "whining" & "constructive input" comes down to attitude & communication skills ... and varies from driver to driver.
      Example #3
      LF 636 # RF 616 #
      LR 650 # RR 670 #
      If it were reversed ... and looked like the #'s above ... again not counting other aberrations in the suspension, this car would have a little more grip on right hand turns & a little less grip on left hand turns. If the car handling was "neutral" on right hand turns, it would be a bit looser on left hand turns. If the handling was "neutral" on left hand turns, it would be a bit tighter/pushy on right hand turns.
      Example #4
      Both examples #2 & #3 show SMALL amounts of cross weight difference. Bigger differences in corner weights make bigger differences in the results, but the effects are the same.
      LF 736 # RF 516 #
      LR 550 # RR 770 #
      If the differences were larger ... like the example above ... the handling differences from right turns & left turns would be HUGE.
      If the car handling was "neutral" on right hand turns, it would be a VERY loose on left hand turns. If the handling was "neutral" on left hand turns, it would be VERY pushy on right hand turns.
      By the way, this example is not a simple tuning adjustment.
      In most cases, it is undesirable to have any cross weight for road racing or AutoX cars. There are exceptions.
      Years back, we raced at a shifter kart track that had a LOT of fast right handers & only 2 lefts. 1 of the left turns was banked ... which gave more grip ... and the other left hander was a tight hairpin. We dialed in cross weight the opposite of an oval track car, so it had more grip on right hand turns. The banked left hander was still good. And the karts were loose in the hairpin ... which we used to our advantage, rotating the rear end to help the karts turn. That set-up dominated there the 2 years we ran it.
      Example #5
      LF 516 # RF 736 #
      LR 770 # RR 550 #
      So, the casual observer may think oval track racers simply add "wedge" and it would look like this.
      You calculate how much wedge or cross weight a car has ... by adding the opposite corners of LR & RF & compare it the car's total weight.
      The LR 770 # + RF 736 # = 1506# / Total: 2572 # = 58.55% wedge or cross weight.
      * Example #4 would be described as having 41.45% wedge or cross weight.
      But that's not how an oval track car would look on the scales ...
      because they are allowed to race with a higher left side weight balance. Each series or class has a rule written as either a left side percentage maximum, a left side pound maximum or specific rules about where weight can be put.
      In Professional Road Racing & Oval Track Racing, car designers & builders build the cars as light as they can ... and still be structurally sound ... so they can put the weight (lead or tungsten) where they want it. Low, left & centered in the wheelbase for Oval Track ... Low & centered for Road Racing.
      Here is what the scales would read for a real world oval track car with rules calling for a Maximum of 58.0% left side weight, if it still had the same & 51.23% rear weight we have been using in the previous examples.
      LF 616 # RF 637 #
      LR 880 # RR 436 #
      This car weighs a total of 2572# ... with driver & 175# Lead
      Target Cross: 59.0% w/ARB preload
      * It was 57.5% before preloading the front ARB
      Left side weight: 58.2%
      Front weight: 48.77%
      Rear weight: 51.23 %
      So when a Stock Car team is calling for more wedge, they are turning a threaded adjuster "in" on the LR or "out" on the RR ... that is to give the car more grip. If they're calling for less wedge, they are turning a threaded adjuster "out" on the LR or "in" on the RR ... that is to free the car up (less grip).
      They do both of these through the back window.
      * The right side of the track bar is also adjustable through the back window.
      Oval track racing is way more challenging than outsiders know. I love all forms of motor racing ... but I prefer road racing the most.
      Nov 2012
      Sacramento, CA
      WoooHoooo !!
      My little buddy AJ Allmendinger won the NASCAR Nationwide race at Road America!
      Couldn't be happier for him. He needed something good to happen.
      Nov 2012
      Sacramento, CA
      Oct 2009
      San Diego, CA
      Dec 2010
      Quote Originally Posted by j-rho View Post
      Hi Ron,
      Appreciate the perspective here. I wonder if maybe our apparent disagreement isn't really a difference over the underlying principles, but maybe just the way we talk about them.
      Using your scales approach from above, let's take a hypothetical "totally symmetrical car" - everything is the same about it any way you cut it in half. 50/50 weight distribution with its CG at vehicle centerline along the longitudinal or lateral axes.
      Let's say at rest this car looks like this on the scales:
      {At rest baseline}
      LF 500# RF 500#
      LR 500# RR 500#
      Left side total: 1000#
      Right side total: 1000#
      Front total: 1000#
      Rear total: 1000#
      Now let's say we did something to simulate a cornering situation - maybe we attach a cord to the CG, and pull directly horizontal with some force F. Our tires stay stuck to the scales, but that force rolls the car just as it would in a corner, and based on this car's setup, now our scales read:
      {Cornering force F baseline}
      LF 750# RF 250#
      LR 750# RR 250#
      Left side total: 1500#
      Right side total: 500#
      Front total: 1000#
      Rear total: 1000#
      Now, we do something to stiffen the front swaybar some amount. But we did so without adding weight or changing anything else about the car. At rest, it still looks the same:
      {At rest stiffer front bar}
      LF 500# RF 500#
      LR 500# RR 500#
      Front total: 1000#
      Rear total: 1000#
      The difference, is now what happens when we apply the exact same lateral force F, now that we have increased the front roll stiffness?
      I contend we will see something like this:
      {Cornering force F stiffer front bar}
      LF 750+X# RF 250-X#
      LR 750-X# RR 250+X#
      Front total: 1000#
      Rear total: 1000#
      I contend we haven't changed the total resulting total load on either the left side or right side tires from baseline, even though the car might visually be leaned less now in response to the same lateral force F (e.g. we haven't reduced the total amount of weight transfer). Whatever additional weight transfer X occurred on the front axle, will be the amount of reduced weight transfer we see on the rear axle.
      When I read "Stiffer bars reduce roll angle, engaging the inside tires more." What I hear is one of the classic misconceptions in vehicle handling (which seems out of place amongst your otherwise correct information) - that quantity of roll is directly related to quantity of weight transfer, and the more roll, the more weight transfer independent of lateral acceleration. A corollary misconception is that which says the car that squats more, has more rearward weight transfer. I think the basis of this misconception is that when you see two cars with identical setups, and one is rolling more, then there is more weight transfer - but only because that car is cornering harder (more torque about the CG).
      If stiffening the front bar resulted in more weight on the inside wheels at the same lateral force F, where is that load coming from? Since our car can't magically gain weight, it has to come from reduced load on the outside tires. This all means a reduction in front-view torque about the CG, and there is no other force available to counteract the torque presented by the cord tugging at the CG. It doesn't add up.
      What does make sense is "Stiffer bars reduce roll angle, engaging the inside tire on the other axle more (but not the "inside tires" as a whole)" - if you can live with that interpretation, then maybe we can find some agreement.
      Jason is on the money with regard to weight transfer vs CG height and track width, I was wondering if anybody would bring that up while browsing through this very interesting thread.
      I may have missed it but steering Akerman can be a cause of understeer on slow speed tight radius corners especially on new tire designs with very short sidewalls.
      Jul 2011
      NC
      Let's talk anti-roll bars
      Ron,
      Thank you so much for sharing your knowledge! I've been asking many of these same questions & basically have the exact same issues as Matt but with a Speed Tech torque arm setup... My build started as a restoration that quickly turned into auto-x racer & wondering why the "REALLY" bad push in corners...everyone would just tell me to slow down going into corners...yes- some of it is inexperience driving but i feel it was more the cars bad setup...The car wasn't built correctly from the start for racing(275F/345R tires & stock spindles)...with almost everyone on the auto-x scene switching to wider fronts the last year it really got me thinking about my setup & reading this has really confirmed where i need to start making improvements to go faster! So i dont highjack this thread- i'll reread everything again & go along for the ride! I would like to get back with you at a later time with my specs for setup if possible? Thanks for breaking everything down!
      Josh
      Josh
      "Schism"
      69 camaro
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by diesel25lrs View Post
      Ron,
      Josh
      You're welcome Josh. After you re-read all the tech stuff ... if you have questions pertinent to this thread ... feel free to chime in here. If you have questions concerning your car & specific handling issues & solutions, let's start a new thread.
      What part of NC are you in? I travel to the Mooresville & Concord area occasionally.
      Jul 2011
      NC
      Ron,
      Sounds great! I'm just south of Raleigh about an hour in Pinehurst. M-ville is only 2hrs from here... You must be doing some NASCAR tar testing over that way...
      Josh
      "Schism"
      69 camaro
      Nov 2012
      Sacramento, CA
      Ron,
      Josh,
      That was funny. No, we're not doing "Tar testing".
      I still work with Penske, Roush, RCR & Gibbs on sponsorship stuff I can't discuss publicly. I expect to fly back there again in August. Often I fly into RDU because I have a zillion Southwest Air points & they don't fly into Charlotte. Flying into RDU makes it easier to go to RCR first, then spend my time in Concord, Huntersville, Mooresville, etc. I like to stay in Concord, by the Mall, because there are so many restaurants and it's close to the dirt track, Concord Speedway's two tracks & the big Speedway.
      Is there any cool ProTouring stuff or AutoX going on back there?
      Aug 2010
      now In Dandridge, Tn.
      great info Ron. I enjoyed talking with you in P-town (I have the red C10) Thanks for helping out. Some of the tuning points for Matt have me thinking.
      Nov 2012
      Sacramento, CA
      Quote Originally Posted by RobNoLimit View Post
      Hi Rob !
      I enjoyed talking with you too. I love your truck. My best buddy has a sweet '69 C10 short fleetside that I have first dibs to buy when he's ready to sell. I'll probably paint it red & black, since those are my colors.
      You have a great chassis & suspension package. I would love to work with you on set-up and/or geometry stuff ... and go do some test days if you want. We might find a few more tenths with some TLC.
      Jul 2011
      NC
      Ron,
      Yeah-thats the racer's haven over there! Let me know when your coming for sure & i'll cruise the hotrod up & grab some dinner with you!
      We have a few good races around here- RTTOS in SC, RTTH- pigeon Forge, TN, GG-Charlotte & of course DSE HQ is just outside of Charlotte- must see if u haven't been there yet! I have about 4 good friends within an hour of me that all have PT cars so the scene is not huge but growing here!
      Josh
      "Schism"
      69 camaro
