      Vincennes, IN
      Master/Booster Advise!
      I need to replace my leaky master and was going to go with Detroit Speed master/booster 9" dual or a wilwood master with a 8" dual booster. Is one better then the other or would they both perform well.
      I have baer 6p Front and Rear with a 11" single booster. Im getting 12 lbs of vacuum, Detroit Speed said that thats what the 70 camaro test car has and brakes work fine.
      Would love some feed back,
      Templeton, CA
      I told them I was pulling 8" of vacuum and they told me the same thing!?
      I purchased the DSE set up and love it. My Wilwood was leaking through the lid screws and they were tight! I like the fact that the DSE sits level and I don't have to jack up the rear to add fluid.
      The brakes are great and now I have to be easy on the pedal. I'll be installing disc in the rear and then I'll be playing with the proportioning valve.
      Any other questions just ask.
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
