    Results 1 to 17 of 17
      Mar 2013
      Grand Cherokee Steering Box
      I want to use a Lee or DSE or ATS etc steering box but they are out of my budget. After reading here I found out several people are using the Jeep box, and that is probably more in line with my budget. I was wondering what year(s) I should be looking for. Thanks for all replys.
      Ron
      May 2011
      Chippewa Falls, WI
      93-98 Jeep Grand Cherokee box. works great. Bolts right in. reuse your power steering pittman arm. the line fittings are metric but you can get the low pressure adapter at a parts store. Not sure about the high pressure since I converted to a metric PS pump due to the LS swap. There is a thread on team chevelle about the swap.
      HTH
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
      Alot of my customers have done this swap and haven't heard anything negative yet.
      Feb 2008
      Minneapolis, mn
      93-98 as stated, I paid less than $50 from the JY, then I ordered the rag joint and hose adapters from Lee.
      http://lee-powersteering.com/rebuild-misc.htm
      It's an easy swap.
      Sean
      50 Willys Pick up.
      Dec 2008
      Detroit
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      May 2008
      Sacramento, CA
      I got a '98 JGC box at a wrecking yard and had Tom Lee go through it. I installed it in my '65 Chevelle and I simply love it. It's quick and precise on windy back roads and very stable on the freeway. It was a straight bolt in and worth whatever it was that it cost me. There is a great sticky dedicated to the subject at http://www.chevelles.com/forums/showthread.php?t=334534 .
      Lou
      If you can't fix it with a hammer, you have an electrical problem.
      Jan 2013
      Cypress, California
      Keep in mind those that have a car with manual stearing you will have to buy the power stearing Pittman arm and the power stearing drag link. I did this on my 1965 Buick Skylark. As reported above there were no problems in the conversion.
      Mar 2013
      Thanks for the replys. I'm going to hit the J yards. It is for my '68 GTO it already has PS so the swap should be quick.
      ron
      Dec 2008
      Detroit
      Quote Originally Posted by 455 Ron View Post
      ron
      Spend a couple of bucks and get a rebuilt box from your local parts store. I'm all for saving a buck or two, but at least you know what you have when you put it in.
      Chris--
      Feb 2012
      OK so I found this and thought....maybe save some money.. Autozone lists a "Duralast" brand gear #7525. Looks to fit both grand and just the cherokee. They show it a 3.3 turns lock-lock, anyone know what the actual ratio of these boxes are? Somehoe that doesnt seem much quicker than stock.
      Feb 2012
      Might have found me own answer......found this at
      http://classicoldsmobile.com/forums/...x-upgrade.html
      YEAR ALPHA CODE ORIGINAL APPLICATION GEAR RATIO EFFORT T-BAR SIZE TRAVEL
      1992.5 -1993 AL or BT Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
      1994 AL, BT, or PD Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
      1995 JH Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
      1996 KD Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
      1997-98 WK or BT Jeep Grand Cherokee 12.7:1 20-26 0.195 Dia 43deg 45min
      Feb 2008
      Minneapolis, mn
      Quote Originally Posted by hotrodneb View Post
      Use car-part.com to find the best price on a used one. I picked mine up for $50.
      and dont worry too much about how many fewer turns, I think the JGC box was 3/4 of a turn faster then the OEM 1972 bex, but my old one was leaky and sloppy.
      Sean
      50 Willys Pick up.
      Mar 2013
      One more question. Is it doable for a DIYer to rebuild the box. I haven't seen any kits at the auto parts stores, was wondering if any of you have tried to rebuild your own.
      Ron
      Feb 2012
      Even if it was possible.......I wouldnt try it. THe time/cost to rebuild yourself isnt worth it compared to just buying one. Same thing for brake calipers/etc......used to reduild my own years ago, but now to can buy one rebuilt with a warranty for less than the kits seemed to go for.
      Goy my used JGC gear at local yard...$45 from a 98 with only 69K miles....no need to even think of a rebuilt---this one should be good for another couple hundred thousand
      Mar 2011
      Nov 2012
      ocala fl
      Yhe steering box adapters are available from Earls. Use a 1980 Camaro/Firebird steering coupler. It is cheaper. I got mine from NPD. Was a lot cheaper than the PU coupler.
      Oct 2013
      Country Flag: Norway
      Is this the same recipe as for any 70's GM car? Want to do this on my 70 Camaro. Same Lares 202 Rag joint and everything to convert?
