      Feb 2012
      AC Compresser notch panel
      Sometime during all my internet reading I came across someone who made a pre-formed piece that was made for notching the subframe for a passenger side low mount AC compressor. It my memory thought it was DSE, but couldnt find it on their site.
      Any help here for an old guy with a bad memory???
      bowling green,ky
      Brp hot rods. I have one in my 69
      69 Camaro
      03 z06
      90 mustang coupe
      Feb 2012
      That is IT...Thank you.....you may now carry the title genius for the day
      and ony $25 too
      Jul 2012
      Lake Mary, FL
      hifi,
      Any details on your setup? I have a notched frame as well, but have not got the power plant in it yet. What compressor you running? Drive setup?
      Jack~
      1969 Camaro Convertible - In Progress.
      Body Mods, LSx TT Setup, T56, 4 Link, Lowered, the works.
      Feb 2012
      '68 firebird with LS1/4L60E conversion in progress donor was a '98 Firebird
      Bowler trans crossmember from member here
      eGay cheap adapter plates
      Replaced pontiac engine stands for small block stands and mounts in "stock position
      Stock F-body engine accessories
      Dumped stock AC compressor (variable output) for TRSA12B (Trailblazer SS-fixed)
      GM part # 12593247 bracket and Dorman #419-109 tensioner
      The bracket required EXTENSIVE modification that could NOT be done by most. I had to modify and move the entire bracket rearward 0.400" but was able to finally get it to run in the original position and off the 4-rib belt. I have JUST enough clearance between the compressor and engine mount for the head of the through bolt, and will have to modify one leg of the stand when doing the frame notch.
      bowling green,ky
      Quote Originally Posted by Boostable View Post
      hifi,
      I am running corvette c5 accy with a sanden compressor with the vintage air adaptor plate. Works perfect. Been on car for 5yrs
