      proper spark plug heat range
      I have a HO454 crate motor from GM. It says it uses a Accel 0263 spark plug. I have installed fuel injection and a Procharger D1-SC supercharger. I ran into a guy who said I should be running alot cooler plug with the Procharger. Anybody know about this and how much cooler would it be. And a part number if you know it. The plug I have in it today is a AC Delco R42T. The engine runs hot.
      1969 Camaro, GM PP HO 454, Procharger D1-SC, 12 bolt rear end, 3:73 gears, 700R4, Borla XS mufflers, X pipe. Ride Tech Air Suspension and Retrotek Speed EFI. AR S200 wheels and Nitto 555. Wilwood 6 piston with Hydratech boost.
      Nov 2012
      Sacramento, CA
      The Accel 0263 is simply a 5/8 hex, 14mm thread with .460" thread reach & tapered seat ... non-resistor ... racing spark plug. The 3 on the end is Accel's heat range #, which is close to an NGK #8 or AUtolite #3 on the end. So, it is a not a "hot" plug by any means, but not a "cold" plug either. it is equal to a NGK R5673-8 & Autolite AR133.
      The Accel plugs are good, but hard to find. I find spark plugs are like oil & beer. Every guy has his own preference & he'll spend hours telling you why his oil, beer or spark plug is "the best".
      We have dyno tested & raced everything from 1-prong, 2-prong, 4-prong, no prong ... from $1.99 plugs to the $18 Formula 1 plugs from Brisk ...
      If we had found a brand or style that was superior ... we would have used them. But, in all of our years of dyno testing & racing I have found NGK's & Autolites are as good as any other brand at building power. Not better ... just as good. The bonus is NGK plugs ... and especially Autolite plugs ... are available almost everywhere, come in wide range of heat ranges for each application & are often very affordable.
      If you want to go 1 step colder, the #'s are:
      Accel 0262
      NGK R5673-9
      Autolite AR132
      Champion V59C
      If you want to go 2 steps colder, the #'s are:
      Accel 0261
      NGK R5673-10
      Autolite does NOT offer a AR131
      Champion V57C
      NOTE: The plugs above are all NON-Resistor spark plugs, so if you're going to run a radio or data acquisition, you may need resistor spark plugs, which will be harder to find in this cold range.
      Somebody said you need gap them smaller so they don't blow out also. Any recommendations on this?
      Nov 2012
      Sacramento, CA
      Bigger gaps can be a problem to "keep lit" where there is a lot of fuel (alcohol & nitro) and cylinder pressure (from "ultra high" compression or boost) ... so yes, you'll want to gap it on the lower side.
      I have a lot of current racing experience with normally aspirated engines. But, I not been involved in blown engines since the 80's, so I do not have "current" experience with boosted engines & ignitions. You need to talk to someone with a LOT of real world experience running boosted engines today.
      We "used to" run the gaps around .022" with a magneto in blown alcohol engines. Less gap hurt the top end power & more gap ran the risk of "washing out the flame". I have no idea what works optimum today. Again, I suggest you reach out & ask someone with LOTS of modern boosted engine experience.
      Thanks Ron. very helpful.
