    Page 2 of 2 FirstFirst 1 2
    Results 21 to 37 of 37
    1. #21
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      Fuel Mileage Discussion
      To increase fuel economy one thing that will help is holding a constant RPM, there are conflicting reviews for "cruse control" I have used "cruse" on my last semi as an engine "RPM control" I used a system from CJ Whitney. Installed as directed, except the magnet went on the engine instead of the drive shaft. It increased milage from 6.5 to 7.3 average, I ran over weight loads, my weight ranged from 95 - 120,000 on 7 axels. The sqf facing forward over weight made the biggest difference.
    2. #22
      the easiest path to better fuel mileage is to install a vacuum gauge where you will see it every time you glance down at the speedometer... you will gain a mile or two per gallon once you learn how to maintain speed without making the needle twitch all over the place..
    3. #23
      Newbury Park, CA
      Quote Originally Posted by 69MSA View Post
      I keep forgetting your car has "only" 490/490 at the wheels. The butt dyno always gets confused when I go for a ride on the autocross with you. That engine of yours just flat out pulls, especially in the low to mid range. Now I find you're getting mid 20 MPG going down the highway? That LS + Magnacharger is a hard combo to beat, especially considering I seem to recall you had the cooler figured out as well.
      One observation that someone had at VIR on One Lap to my co-driver was "he seems to be taking it easy through there." That could not be further from the truth. The car is putting down 450+ft-lbs of torque starting at just under 2500rpm. To save the engine, reduce heat, make it MUCH easier to drive, etc. I make a point of driving the car one gear up from what an N/A engine would normally be. Observers might not hear the engine screaming, but the torque was overcoming the tires the whole time. The peak power might not be all that high, but the under the curve area is huge.
      As with anything like this, there are drawbacks. The supercharger adds weight to the part of the that least needs it.
      The really nice thing about the setup is that since the engine/tranmission package was installed in 2008 the only things changed are the spark plugs. RPM kills engines faster than mild boost in a engine with simple but correct parts. Mine is limited to 6500RPM but I rarely take it over 6200RPM. With the small cam, a Lingenfelter GT2-3 (similar to LS6), and reasonable gearing, it's a cupcake to drive and gets good mileage.
      Most all of the OE's are using forced induction for high-horsepower builds. Small cubic inch engines provide good fuel mileage, emmisions, driveability, etc. while the supercharger becomes the great equalizer.
      I do agree with Scott that for most situations chasing the aero gobblin is not worth it simply for fuel mileage on our cars. To really get it right would mean turning the car into something we might not recognize. The Camaro still knocked down 23-24mpg highway before the aero. However, going from a 400CI SBC/TKO to the current SC LS1/T56 increased the fuel mileage by almost 35%, made it much less smelly to drive, much better to cruise, nicer starting, etc. Besides the cost, there really is no downside from a mileage/efficientcy standpoint. I don't keep track of city/spirited driving MPG, it's better not to know.
    4. #24
      Oct 2012
      I used to have a jacked up 84 Chevy pickup when I was in high school. Someone asked me what mileage it got... I told them that wasn't what I bought it for!
    5. #25
      Colorado Springs
      Poking around the interweb, I've found the following cd numbers for Camaros (figured I'd use these since so many people own them)
      1st gen .38-.42 (Id guess the hgiher end of things)
      2nd gen .41
      3rd gen .37
      4th gen .32
      5th gen .36
      So over 40 years of evolution, the aero figures have not improved dramatically while mileage figures have gone up significantly. So that tells me a few things. First, engine/trans technology is the driving factor behind mileage improvements. 2nd, aero in passengers cars is more about reducing wind noise and buffeting for interior comfort. 3rd Aero on performance cars is more about stability and control.
      I forget if it was Warren Johnson or Reher & Morrison who said the 3rd gen cars were faster and more stable than the 4th gen cars, despite appearing much slicker. That actually makes sense if you think about the hole your punching in the air is dependant upon the front profile and not so much on how slick the car appears to be.
      So, while you can add some aero tricks to improve downforce, smooth out flow, or reduce turbulance, on a street car you are talking about improvements of .0x to .00x percent of change. That's a pretty small amount of return. So if the effort is simply bolting something on, it migh be worth it. If it is fabricating for days with multiple test fits, installs and removes, and material consumption, it probably isn't worth it unless you just want to have the "cool" factor of having something no one else does. With the popularity of Camaros, that may actually help seperate your car visually more than some others, and goodness knows it is hard to find something fresh on 1st gen Camaros.
      TonyC@HP2
    6. #26
      SC
      I'm obviously more concerned with SPG, (smiles per gallon)
      433 cu in, 525hp, dual AFB 500's, M20, 12 bolt 4:11
    7. #27
      Oct 2008
      texas
      Quote Originally Posted by ho428 View Post
      You got short trans syndrome.....
      This is Larry Callahan adding to Rocky's profile.
      I'm sorry to say that we have lost Rocky.
      RIP....
    8. #28
      SC
      Quote Originally Posted by rockytopper View Post
      It's not the size of the box, it's how you apply the torque...
      We are still talking about cars... right?
    9. #29
      Oct 2012
      I had to google CD to see what you were listing for the different generations of Camaros. Came across a wiki article that was very interesting....well, to me anyways!
      http://en.wikipedia.org/wiki/Automob...ag_coefficient
      If the 4th gen had a better rating, how could the 3rd gen still be better?
      I understand that being more aerodynamic isn't the most important thing and the engine/throttle controller/gearing are the most important, but it's just a fun conversation meant to inspire thought and learn something.
      I had never known about cd ratings, and would have (probably) never read that wiki article if not for that one response. That's the kind of thing I'm trying to get out of this thread!
    10. #30
      Colorado Springs
      Okay, then you might be interested in some of these as well;
      Undertrays, Spoilers & Bonnet Vents, Part 1
      http://www.autospeed.com/cms/A_2159/article.html
      Undertrays, Spoilers & Bonnet Vents, Part 2
      http://www.autospeed.com/cms/A_2160/...popularArticle
      Spoiler discussions;
      Part 1
      http://www.autospeed.com/cms/A_2455/article.html
      Part 2
      http://www.autospeed.com/cms/A_2456/article.html
      And since this was generated by an S10 inquiry:
      http://csus-dspace.calstate.edu/xmlu...pdf?sequence=1
      Front Airdam from Garden edging.
      http://forums.pelicanparts.com/off-t...effective.html
      Tailgate spoiler
      http://forums.pelicanparts.com/off-t...xperiment.html
      Cab roof spoiler
      http://ecomodder.com/forum/showthrea...1-a-19525.html
      TonyC@HP2
    11. #31
      Newbury Park, CA
      The CoD is an important part of the equation. On older cars the grill area also acts like a parachute, and the engine compartments can become pressurized when at speed. That can cause front end lift, which leads to worsening aero. Minimizing frontal area and grill openings is all good if the waste heat can be controlled.
    12. #32
      Southern Indiana
      One thing comes too mind, an old physics instructor of mine was trying to teach several of us about certain erroneous elements in coefficient of drag ratings. He used to help design bodies for race cars and he showed us 4 cars, and asked us to deduce which was faster and which was slower.
      I won because after looking at the designs I saw that two fo the designs worked against the whole car as it had TOO MUCH down force, and this lead to it taking up too much power to over come the down force imposed.
      As we discussed the forms I asked the instructor HOW he figured out they didnt work. His response was the one design compressed 1800lb coil springs and actually destroyed the sidewalls on a heavy walled high speed tire,, at 80 mph.
      HIS design was too good. It actually help a 1000hp turbocharged car BACK from making any true speed.
      The fact is it doesnt take perfect CoD, just appropriate amount of it along with appropriate amount of traction applying design and they had a much better handling vehicle,,,and it had 3 times the CoD of the original, kind of looked like a cross between a Lambo Countach and a 69 Camaro.
      As made clear, mileage is NOT an efficient body design, its efficient use of the power on hand in which is applied in the most efficient manner possible.
      A fine balance is required in most designs, and isnt it amazing how ,we, simple hot rodders ,can design cars that do so much MORE than the original version of our each pet projects, and these redesigned automobiles seem to exceed all of the original design parameters,,and provide economical AND personal accomplishments that are actually incredible for the way we design and build them.
      Again I have noticed much benefit of tuning timing AND fuel over aerodynamic designs. More benefit of using gearing and such over aerodynamics,, my point is a fellow who restored a 57 Chevy, all he did was install an LS1 and and a 4L60E.
      No other changes.
      That car has ,to date turned over 32mpg,,,in a BRICK!
      And he hopes to tune in more after switching out a similarly tuned new version of the LSx engine design. she still wears drum brakes, only newer tech is driveline and radials. past that its all 57 Chevy.
      This car is not lowered from stock, the tires that are on it are reproduction sized in similar fashion, ie some Coker repop radial wide whites.
      So it sure isnt aerodynamics there.
      He gained a little over 1mpg in tuning TRANSMISSION software.
      He is also using Megasquirt and its transmission controller, and has been tuning with a wideband O2 over narrow band. He finds it easier to maintain fuel control and mileage.
      He also has some interesting ideas about air cleaner design and conditioning air going into an engine.
      Guess I need to get him in here laying out some of his findings,,, he also has found that many engines can benefit from advanced timing adjustments and controls.
      Lee Abel
      AFTERMARKET PERFORMANCE
    13. #33
      Sunny Florida on the Suncoast
      Are we talking at race speeds or regular driving speeds. Seems to me that unless we talking about a specific race series that limits the numbers of stops or fuel, that this is a question about highway speeds and driving.
      Here is my take on the situation. My Chevelle has a GM crate 350, which is basically a 96-99 GM Vortec 5700 with a bit more cam and minus fuel injection. Running a Edelbrock 650 on a RPM Air gap, with a 268 Comp Cam, 3.31 gears, and a TKO600 has gotten me a best of 22 highway @ 75 average. In a 1968 Chevelle with no Aero tricks of any kind and not a light foot (just ask Hollywood how I run my car), it is a very reasonable number.
      Reality is that the best thing anyone can do to improve MPH is to gear the vehicle to the lowest RPM of the torque band, Mine loves to run right at 2100. Next is driving style and vehicle condition.
      When I was at Guldstrand in the late 1980's, we were working on the GS80 Corvettes and their 372 TPI Tracos, it was very easy to pull 28 MPG that is without the modern super efficient cylinder heads.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
    14. #34
      Oct 2012
      Loved all of the links that were posted, great info.
    15. #35
      Jan 2010
      Delaware
      Interesting thread...thought I would resurrect it. I've had an interest in high mileage capable cars for quite a few years. Ever since I realized my dollars were filling the pocket of some arab who considers me so unimportant he wouldn't bother to look down his nose at me. Went so far as to purchase a 92 Civic VX...a car only made from 92-95 with their e-vtec (e for economy). These cars are capable of 45-50 mpg with good driving, and I have no clue why Honda didn't fire up the old molds to remake such a simple car 8 yrs ago. They are also rare, and popular with the hyper-miling crowd.
      A guy has taken one of these, modified it aerodynamically and gets 95 mpg with it. States it is so aerodynamic, new people driving it let off the gas as they approach a stop figuring the car will slow and stop...but it doesn't and they end up needing the brakes. Here's a link for those that are curious.
      http://aerocivic.com/
      Those of us with muscle cars, or pro-touring cars aren't going to modify our cars like that. But we COULD potentially increase mileage AND positively affect performance at high speeds by reducing the amount of airflow into the engine bay as High Plains Mopar was showing. Air entering the engine bay needs an outlet, and it CAN be done. Air dams up front can limit the air flow going under the car, and if done properly keep your car from floating at high speeds by creating a negative (relative to surrounding) air pressure just behind the air dam while limiting total air flow under the car, and finally for those who really want to play one COULD use a belly pan under the engine bay, or even under the whole car to smooth air flow.
      I can tell you this DOES make a difference. I wondered why my Subaru forester's gas mileage seemed a tick down from previously, until I remembered I had left off the whole plastic belly tray under the engine. I started calculating, and it seems to me I get 26 mpg with the tray on, and 24-25 without. Am I somehow driving differently during those two periods? I guess its possible. lol
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
    16. #36
      Jan 2014
      Seattle WA
      Start with the transmission if you want better fuel economy. Final drive on a T56 with .50 gave me around 17-19mpg with an 800hp "street tune" on my Chevelle. 4.56 gears in the diff. Looking for similar or better results with this El Camino I'm building, possibly better with 4.10s and the same final drive T56.
      1967 El Camino 408ci LSx....and the build begins!
      1967 Turbocharged 408ci LSx Chevelle - 1012 rwhp, 959 rwtq 67 Chevelle
      2009 Supercharged Silverado - On the Dyno
    17. #37
      Cornettsville, ky
      a stock 69 skylark would pull 21 mpg all day with no overdrive in stock form so idk if the ls1 is that much difference in fuel milage. the biggest play is the gearing and less weight that includes parasatic loss. the areodynamics of a c10 arent much worse than a modern truck for that matter. most that have overdrive and a properly tuned engine really got no worse in mpg than mordern truck.
