      Mar 2013
      hurst comp. plus shifter
      Apparently I have a hurst comp. plus shifter for a "Chevy " as the shifter lever bolts straight into the mechanism. My Camaro requires the lever to bolt into an offset piece that isn't available through hurst individually?? So am I up against buying a whole new shifter or does anybody have a quick fix to off set the handle or possibly an old junk shifter that has the off set piece that they'd be willing to part with??? Thanks, Tim
      Dec 2010
      Fredericksburg, VA.
      What transmission?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Mar 2013
      M21 thanks
      May 2013
      King NC
      I have the same problem. I bought my Muncie from a guy that has a 63ish Nova with no console. He just had the Hurst Comp Plus shifter and the handle came straight up from the shifter body. Seems like I read that the Camaros are supposed to be offset to right about 2 inches. It also looks like it''s offset to the front about an inch. I'm going to cut and modift a piece to do the offset, install the shifter and look to see if it's in the center/correct location of my console then I'm going to modify or weld the new piece in position. If it works, I saved 300+ bones on having to buy a new shifter. If anyone else has an opinion, better suggestion, pics, etc, pleas chime in. I may be doing my muncie swap this weekend! Always open to a new better way!
