      FS - ZR1 LS9 Setup
      FS as have ZR1 engine components
      LS9 Supercharger Assembly - This is complete with the intercoolers, throttle body, manifolds, injectors and fuel rails. Also includes the sensors, bypass valve, etc.
      LS9 Engine Block - Complete block with oil squirters and billet main caps, has the stock main bolts still installed.
      LS9 Heads - They have stainless valves installed and double wound 0.660 lift springs with Ti retainers. Heads have already been squared up, valve job checked, etc. They are ready to bolt on.
      Rockers, Intake and Exhaust.
      Rocker Supports for the Heads.
      Lifters
      Lifter Retainers and Bolts
      Accessories - This is a complete accessory setup, includes all brackets and bolts, Power Steering, Alternator, AC, does not include the belts, but has all the bolts for installation, all idlers, etc.
      LS9 Water Pump
      LS9 Valley Cover
      LS9 Head Gaskets
      ARP 12pt Head Studs - new Kit 11mm studs. This block accepts the standard 11mm studs.
      Asking $11,500 for everything.
      Located in Knoxville, TN
    Tags for this Thread
