Thread: Edelbrock leaking fuel from top.
- Aug 2004
- Parkland Florida
- 100
Without going into too much history I noticed it seemed like my edelbrock 1806 AVS was flooding out at stoplights. So I researched a bit and took the top off to adjust the floats. They seemed to be waaaayy out of spec so I adjusted them and put it back together. Now I have fuel coming up next to the port by the needle thing (sorry nomenclature escapes me right now) and the accelerator pump. This is only happening on the drivers side. I have taken it apart again and blew carb cleaner around but didnt fix the issue. I will disassemble again tomorrow but I was hoping someone could give me a tip on what to look for (no throw away the eddie comments please
Also I noticed that fuel continues to drip in the primaries after the engine is off. Is this normal?
I dont know what the fuel pressure is but the mechanical pump is the same one from before the problem appeared so I dont think its that.
I will test pressure at some point though
thanks
Jason1968 Camaro convertible. 383ci, 700R4, C5 13" brakes up front and C5 wheels all around. Oh! anda Hydroboost unit too!
