      May 2013
      Damn Header clearance
      In process of adding tru turn steering on my 68 camaro. Had a set of headman headers 1/3/4 they would not work with the tru turn. I spoke with Ride tech and they recommended dyna techs which now the true turn will fit but the new headers will not work with my AGR steering box. Does Anybody know if the 605 or 700 saginaw is actually a smaller unit then the 12/1 agr box? The dyna tech headers are 1 3/4 step headers to 7/8. Thanks for anybodys help.
      Pensacola, FL
      I'm kinda surprised the dynatechs dont clear your box. They have the most clearance I have seen yet, and the tube that normally has clearance issues is routed up & over the top & not down next to the box. Is your motor set very far forward or back?
      May 2013
      The motor looks to be in factory location. The Number 5 primary tube runs straight down alomost even with box, didnt know if the the AGR box might be wider or bulker than oem p/s box ;ike 605 or maybe 700 saginaw.Dyna tech part number that I have is 329-740-21310.
      Pensacola, FL
      OK I was thinking their LS1 headers. I jumped the gun on that one. I haven't used the agr box before. Have you spoken with dynatech to see if the agr works with their headers?
