    Results 1 to 10 of 10
      Sep 2012
      Los Angeles
      Looking for a Weld up Header kits for sbc
      Hey guys curious on a good company that makes a weld up header kit for a small block chevy i need to make a set for my 67 elco
      thanks!!!
      Nov 2012
      Sacramento, CA
      inside the frame rails ? ... or outside? Stock clip? or fab clip?
      Sep 2012
      Los Angeles
      inside the frame rails i have the motor moved back too thanks ron
      Nov 2012
      Sacramento, CA
      Here is a link to Dynatech headers. The ones shown fit Chevelles (and therefore El Caminos) with the engine moved back. As it says in the notes, #1 spark plug should be 1" or more behind upper ball joint.
      Link: http://www.dynatechheaders.com/ct_chassis.html
      These are racing headers. you can weld a 3-bolt flange on the end to run the rest of your exhaust, or use a slip on tube with clamps or bolts. Because they are a race header, they are equal length for performance & shorter in height ... for ground clearance with low ride heights.
      If this works, you can get them ready to bolt on, from any Dynatech dealer. (around $220 +/- ). If you need them unwelded, I can probably get them that way from Dynatech, but I suspect the cost will be same, since unwelded would be special order.
      Nov 2012
      Sacramento, CA
      Shane,
      I asked my Dynatech rep, and unfortunately they do not offer that header kit "unwelded". So you would need to buy it welded and use "as is" ... or cut & weld as needed for your application. It's inexpensive enough. (Cheaper than many kits)
      Is there any reason it won't work "as is" ... for your application ?
      Dec 2010
      Fredericksburg, VA.
      Stahl has weld up kits.
      http://www.stahlheaders.com/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Nov 2012
      Sacramento, CA
      Steve,
      I couldn't find an unwelded header kit that was made for the early Chevelle (or El Camino) with the engine moved back (like Circle track racing) on the Stahl site. Can you post us a link ?
      Sep 2012
      Los Angeles
      Thanks guys sorry for the late response checking them out right now.. Fabricating up a few cars for need for speed movie 14 hour days going crazzy
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      how about using Icengineworks header lay out kit, and cutting jig.
      this there sight.
      http://www.icengineworks.com/icewmain.htm
      HotRod did a article on there kit, this is the heading for it.
      Header Modeling Kit Build - Pipe Dream
      Like Legos for Big Kids, This Header Modeling Kit Makes Building Custom Headers Simple and Fun.
      I think it would have more uses then just headers.
      http://www.hotrod.com/techarticles/h...ld_pipe_dream/
      Nov 2012
      Sacramento, CA
      Thanks doc,
      What a great tool.
