Thread: Master cyl questions
05-12-2013 #1
What kind of research do you guys look for when you use a more modern master cylinder on a classic car. The master on my C3 is bad and i went to replace it and the one I got was bad out of the box. This got me to thinking about using a newer master with a screw on cap instead of that old PITA style cap.
Kacy
79 Corvette, 406 SBC, Holley EFI, 700R4
05-13-2013 #2You just need to make sure the new master is set up for the same configuration (F&R disc in your case I assume) and the same bore if you want to keep your pedal feeling the same. I know the Wilwood tandem master is build around the same basic design as the C3, but a lot prettier.
05-13-2013 #3Actually I would like to move the pedal feel farther away from the pedal.
Kacy
05-14-2013 #4
- Jan 2006
- Oregon
- 1,773
