    Results 1 to 20 of 33
      Oct 2011
      4 link guru's question
      What happens if you have completely parallel links and both upper and lowers are the same length?? I know u would have an infinite IC but what happens to handling and what not. just curious.
      Mar 2004
      Mid-Michigan
      The suspension points not only dictate the IC but they drive the percentage of anti-squat the rear suspension sees. Parallel bars will have a drastic effect on that percentage and could cause excessive roll over steer. That can make the vehicle unstable during cornering. This probably isn't as noticable on a street car but any road course car will have a difficult time transitioning into and out of corners. Just something to think about and if you are planning to "race" the vehicle this needs to be taken seriously.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Nov 2012
      Sacramento, CA
      When you say "completely parallel links " ... do you mean top view & side view ?
      Mar 2004
      Mid-Michigan
      Quote Originally Posted by Ron Sutton View Post
      When you sat "completely parallel links " ... do you top view & side view ?
      By saying "completely" I understood him to mean top and side views. Actually, the top view has no bearing on Anti-squat. Whether the suspension is a 4 link or three link. The IC is derived totally in the side view and anti-squat is adjusted with the bar angles.
      Mark:
      Oct 2011
      yes both top and side. im gonna use the ride tech parallel kit brackets on my 67 Camaro, this car will be just a cruiser for the most part. if it sees track it will be once a year at the lsfest. i had a thought tho, what if i took the frame bracket, and rotated it slightly to where the top link was slightly shorter which would also make it non parallel from the side, the instant center would be far ahead of the front end of the car but would this be better than straight parallel links?? or will there be much difference?? also what if i turn it the opposite direction which would make the lower link shorter?? ive heard its a no no but just trying to work out my options, im building a budget 4 link to get away from the shotty ladder bar setup that's on it now, ive already got the brackets, going to make my own bars and panhard bar
      Oct 2011
      heres what its going to be based off of, no adjustment but long as it rides better than ladder bars ill be happy. im going to keep the coilovers that is already on the car for now.
      should i have the coilovers straight up and down or on a angle like say 20 degrees? whats the difference in ride if any?? I appreciate everyones help on the matter im rebuilding the rear end with 3.55's right now so once i get the details worked out ill start a build thread
      http://www.ridetech.com/store/parall...e-bracket.html
      Nov 2012
      Sacramento, CA
      Hey Guys ....
      Mark, I was asking, so before we responded to help him, we could be clear if he was asking about "parallel 4-link versus triangulated 4-link" ... or "a parallel 4-link with all 4 bars level (or, if at an angle, parallel to each other from a horizontal view). Sounds like you were already clear. Now that I'm clear, I feel I can offer some helpful advice.
      RNation (name please?),
      Every suspension set-up has its own unique pros & cons. The angle you position the bars (tubes) in a 3 or 4 link play a VITAL role in how it operates, and therefore its characteristics and performance.
      You already understand the imaginary lines of the lower link & upper link form an I/C (or Instant Center) somewhere ahead of the rear axle. Where this I/C ends up ... in relationship to the wheelbase & CG of the car ... determines "anti-squat" based in percentages … which is just a simple way for us car guys to put a number to how much leverage the rear suspension has.
      Making the I/C higher and/or closer to rear axle provides a higher anti-squat %. Conversely, making the I/C lower and/or further from the rear axle (towards , or even past the front of the car) provides a lower anti-squat %.
      Simply put, more anti-squat percentage means more leverage. There is WAY more to it than that … and the percentage # is NOT the whole picture. But that explanation is good enough to get you going in the right direction. If you want to know more about 3 & 4-link I/C points & the role they play, just ask. But for now, let’s just keep it simple & use the term anti-squat.
      Basic definition: More anti-squat provides more leverage (utilizing the torque of the rear end housing rotation under acceleration) to load the rear tires, and adds traction, under initial acceleration. More anti-squat = more leverage = more load on tires = more traction upon initial acceleration.
      There is an optimum set-up of anti-squat for each car, that varies with that car’s individual parameters, set-up, needs & goals. A car can have too little … or too much … anti-squat.
      Typically, in 3 & 4-links, you "want" to build in some degree of anti-squat. You don’t "have" to. A lot of “Street Rod” 4-link kits are sold that run parallel. But, running the bars parallel ... where there is never an intersect point ... provides 0 anti-squat. Zero anti-squat = zero leverage = no additional load on rear tires other than static car weight = less traction on acceleration.
      So, if you’re building a low powered cruiser & want to be able to spin the tires easy … run zero anti-squat. But, if you’re building a higher powered, performance car, and want to get some traction to the ground on acceleration, build in some degree of anti-squat.
      Oct 2011
      THanks for the replies. Daniel Nation is the name, maybe i should tell a little about my current setup. i have a 67 Camaro with a Iron block ls1, forged bottom stock heads and intake, 235, 238 cam t56. has decent power will probably spray it slightly maybe 150 shot if i do. this is going to be more of a daily driver than anything. it may see some road courses and strips once or twice a year. this car currently has an older ladder bar/coilover setup on it. and it rides like a go kart, curves suck, and bumps sounds and feel like its gonna jar something off lol. My goal is to have something that rides closer to stock but that i could still take on a road course ( not trying to compete really just have fun.... maybe beat a friend lol)
      if i have 0 antisquat and infinite instant center will it be a dog cornering and tacking off?? the only way i can triangulate is by rotating the frame bracket slightly. and if i do that it would be easier to rotate it to where the lower link is shorter but ive always read u want the top link to be shorter if one is to be shorter. would it be better to have the lower link a little shorter and have an instant center and some degree of antisquat or parallel? and which do you think rides better??
      heres a link to my original build of this car with the exception due to an injusry i never finished the turbo and went natural with a cam.
      http://ls1tech.com/forums/forced-ind...er-welded.html
      Hey Guys ....
      Nov 2012
      Sacramento, CA
      Hey Daniel,
      Let's take these 1 at a time.
      When I think of "dog" I think of the engine being weak or unresponsive. With zero anti-squat, you will have less grip. If that LS engine thing builds power, like it looks it will, it will easily spin the tires & not get anywhere quick. Running it on a road course would be scary, because you won't be able to go hard off the corner, critical to lap time.
      The only way i can triangulate is by rotating the frame bracket slightly. and if i do that it would be easier to rotate it to where the lower link is shorter but ive always read u want the top link to be shorter if one is to be shorter. would it be better to have the lower link a little shorter and have an instant center and some degree of antisquat or parallel?
      Why would you need to triangulate it? You don't. (And you don't want the lower arms shorter. )
      From top view the 4-link bars can stay parallel. But from side view, You can run the lowers "around" level (we can discuss how different degree angles affect roll steer if you want, at a later point) and the uppers bars need to have some down angle (rear higher / front lower) ... so as to intersect with the lower bar at some point forward ... creating an Instant Center within a window to obtain some anti-squat. Somewhere in the 30-60% range would be good.
      Neither of these will have anything to do with ride quality. That will be based on spring rate & shock valving.
      Oct 2011
      Thanks for the info. When i said triangulate i meant from the side view. hmmm im not sure what to do now lol. I already the brackets from the link above. I guess im going to see if i can turn the frame Bracket to where the top link is shorter which would also make the front two angled inward giving me an instant center and small amount of antisquat. Ill look tomorrow if that don't work i guess its back to the drawing board lol. I downloaded a good 4 link calculator from pirate 4x4. im guessing it will work for cars as well.
      I know in a perfect world ideally you want 100 percent anti squat. but what would be a minimum amount that you would shoot for 20? 50? 75? may have to do some altering to these brackets but hoping to get away with small changes to the design.
      Hey Daniel,
      Nov 2012
      Sacramento, CA
      Hi Daniel,
      I've added some tips & suggestions.
      Sorry, I misunderstood. A triangulated 4-link is a common 4-link version where one or both sets of arms are at an angle (from top view) ... different from a parallel 4-link, where all 4 bars run parallel with the chassis (again, from top view).
      hmmm im not sure what to do now lol. I already the brackets from the link above. I guess im going to see if i can turn the frame Bracket to where the top link is shorter which would also make the front two angled inward giving me an instant center and small amount of anti-squat.
      If you move the upper bars "inward" you are creating a mild version of a triangulated 4-link. Because you haven't shown us photos, we can't offer any suggestions on how to do this without "angling them a little" which makes me nervous. When you say I/C in this case ... I think you're talking about the upper left bar & the upper right bar forming an I/C ... which is a triangulated 4-link. Don't "sorta/kinda" do a triangulated 4-link. Either do a true parallel 4-link or a true triangulated 4-link, or you'll end up with other issues.
      You mention getting a "small amount of anti-squat" when you angle the upper bars inward ... which makes me think you are misunderstanding anti-squat as imaginary lines of the upper bar(s) converging with each other (not correct). Anti-squat is based on the I/C formed by the imaginary lines of the upper bar(s) converging with the imaginary lines of the lower bar(s).
      I'll look tomorrow if that don't work i guess its back to the drawing board lol. I downloaded a good 4 link calculator from pirate 4x4. Im guessing it will work for cars as well.
      I would suggest you use a 4-link calculator, but I can't vouch for that one. I use the one from Performance Trends.
      You may be over complicating this. If you mount the front 4-link mounts (hopefully with multiple mounting holes) so you can run the lower bars level with the ground ... and the upper bars at a downward angle (7-12 degrees) you will be "good" and end up somewhere in the 40-60% anti-squat range. That may not be ideal for your application, but you won't know until you run it & test.
      You may have read someone's opinion that 100% is the correct number, but every application is different, and every person's goals are different. You mentioned running the car on road courses. I know I don't want 100% anti-dive in any car I'm going to road race. It would be fighting a loose condition on corner entry, if you drove it in as deep as you need to in actual race conditions.
      If you install a 4-link system with multiple mounting holes, you will end up with an adjustable system you can dial in to your needs. You just need to get it in the ball park to start. Earlier, you were considering having all 4 bars parallel ... therefore having 0% anti-squat. That is what you want to avoid.
      Does that clarify things any?
      Nov 2012
      Sacramento, CA
      I do not want to take you off track ... but I felt this needs to be said so you don't end up learning more down the road ... being unhappy ... and wishing you had done something different.
      The parallel 4-link will be MUCH better than your ladder bar set-up. Your ladder bar set-up ... is in bind the instant the car incurs roll angle. The parallel 4-link will allow the rear end to articulate (rotate within the chassis) MUCH better than your ladder bar set-up.
      But parallel 4-link set-ups do not offer the most rotation. They can rotate only so far & then "bind". A Triangulated 4-link rolls more before bind & a 3 link has even more available rotation before bind. Most road race cars (with solid axles) use a 3-link.
      Again, the parallel 4-link will be MUCH better than your ladder bar set-up. All suspensions have their pros & cons. 4-links are better for drag racing. 3-links better for road racing & oval track. But any will be better than your ladder bars.
      Best wishes !
      Oct 2011
      Hi Daniel,
      No I mean rotating the frame brackets on the side view. which from the top would keep everything parallel (not a triangulated 4 link ), but the frame bracket holds both lower and upper links in one bracket. I mean rotating it so that the upper links would be shorter than the bottom links and it would also move the front upper and front lower points closer together causing me to have and IC. hard to explain but if u look at the links above from ridetech u can kinda see what im talking about..
      Nov 2012
      Sacramento, CA
      Daniel,
      I see what you're talking about now, once I saw the actual mounts in the kit you own. The I/C will be out front a long way, providing small anti-squat percentage. To get more anti-squat, you would need to modify or replace one of the 4-link mount brackets. If you do, the rear mount of the upper bar needs to be higher. If you can get the lower bar level & the upper bar with a 5-10 downward angle, you'll be good.
      Best wishes.
      Mar 2004
      Mid-Michigan
      Hey Daniel,
      Listen to Ron, he knows his his stuff. There are a lot of things you can do to get the upper bars where you want them. You can cut the one piece brackets you have and just rotate the upper portion or make new brackets for the rear to lift the mounting point (pay attention to floor clearance here).
      Like Ron said shoot for 30 to 60% anti-squat. When you start getting higher then that you start to induce brake dive when you step on the brake pedal. You don't want that either as it can induce push into the front suspension when cornering hard.
      Mark
      Mark:
      Oct 2011
      Awesome guys I really appreciate the help, now i just need to figure out exactly how im going to modify these brackets lol. although this is a cruiser there is a couple friends i wouldnt mind whooping up on at the track. lemme ask ya this. ride tech also sells mounting tabs. if i was to weld a mounting tab on the upper axle link it should raise it between 1 and two inchs. think this would be enough??
      Nov 2012
      Sacramento, CA
      That would be good. If you run the lower bar level, and raise the rear mounting point (on the axle) up 1-1/2", that should give you approximately 41% +/- anti-squat. If you only raise it 1" ... you would have approximately 30% +/- anti-squat. That's the best I can calculate with the info I have.
      I would pick one of those 2 #s. I'm confident that window of anti-squat will help your acceleration traction & will work much better for you than zero anti-squat.
      Best wishes !
      Oct 2011
      Ron, I really appreciate your help, and everyone else's on this site, its guys like u that have helpedme in that past go from a primered rust bucket to a decent 67 camaro. im gonna start a build thread for the budget 4 link on here. not sure where ya from but if i ever meet ya ill buy ya a beer for the advice
      Nov 2012
      Sacramento, CA
      I'm in Northern California. Dos Equis Amber please. :-)
      Best wishes.
      Oct 2011
      u should come to the lsfest in ky this year ill have all the beer and moonshine u can handle lol
