    Results 1 to 10 of 10
      Mar 2003
      Petaluma, CA
      wheel sizes for a 72 corvette
      Does anyone have offsets etc for a 72 corvette (stock), currently the car has some UGLY spoke type rims on it that need to go!
      thanks,
      -Jeremie
      absecon, new jersey
      stock sizes you can run a 17x8 or a 18x8 with 4 inch bs and be fine with a 255/50/17 tire,im running a 17x9.5 with 4 1/8 bs with a mild flare onth rears and 17x8 with 4i nch inthe fronts ,rear tires are nitto nt450's 275/50/17 and fronts are 255/50/17.If i remove my rear sway bar i can run a 17x11 with 5 inch bs. which this winter i might do.
      unless your looking to stay with stock sizes then a 15x8 with 4 inch bs is stock.
      73 corvette chop top silver LS6 motor ,LS6 intake,700r4,2400 pro torque convertor ,3.70 gears,modified hooker sidepipes to fit LS1,17 x9.5 boyd starburst,nitto 275/50/17-255/50/17 tires,vb&p suspension,nitrous,L-88 headlights,autometer guages.L88 hood,flares,spreader bar,vb&p sway bars
      lvrpool32 has a nasty 69 Vette and has bought more wheels than he will admit too in front of his wife. Maybe he will chime in.
      Brad
      Mar 2003
      Petaluma, CA
      Thanks guys, the car is actually a surprise for my pops 60th birthday (kind of a dream of his to own a corvette). There are several mechanical issues I need to fix on the car (like brakes....) before we surprise him with it. Unfortunately it pretty much tapped my funds to buy him the car, but it seriously needs some rims so I may have to stick with some 15" ralleys for the time being...... unless you guys have a good source for some cheap 17s..... thanks
      -Jeremie
      absecon, new jersey
      rallys will be your cheapest way out im sure,but the cheapest 17's might be boyd coddingtons or eagle alloys,heres mty boyds.
      https://www.pro-touring.com/forum/vb...do=view&id=122
      hi
      i have on my 70 stingray 285x30x20" back and 235x35x19" front
      absecon, new jersey
      raih what size rims are on the rear and anything different to the suspension?Did you remove or relocate your ebrake cable?
      I have 8.5 x 10 front and 10 x 20 back.
      Yes, i must recolate the exaust pipes and the emergency brake.
      The suspension are original.
      absecon, new jersey
      Well they look great!
      Sep 2002
      San Jose, CA
      The best sizing I have found is 17x9.5 with either 3.75 or 4" backspace all the way around
      Run a 275/40ZR17 tire
      Just call me Brett
