    Results 1 to 9 of 9
      Jun 2009
      Sunbury, PA
      Steering box question
      I am not sure where this should go so please move if I posted in wrong location. I just got a DSE steering box for my 67 Chevelle. I am wandering if there are any fittings that would allow me to use my stock lines with the new box or do I need to spring for the new pump and hoses?
      Nick
      Central CA USA
      Yes there are 45 degree flare to Saginaw metric adapters that screw into your new box.
      Hildebran, NC
      Quote Originally Posted by bergsvette View Post
      Nick
      Are you going to Autocross / track it?
      If so, and your pump is from 67, I would file 13 it.
      Even the small Goodguys peanuts overheated my box / pump / fluid.
      I went with a new Lee 800 box with 12:1 & DSEs type 2 pump. I also added a small (5x8) cooler as well.
      This setup works great.
      Good luck
      Randy
      Jun 2009
      Sunbury, PA
      It is going to be more of a road car but I will get it on the track at some point just to see what I and the car can do. I think for now I am just going to look for the fittings and if or when I puke the pump I will upgrade.
      Central CA USA
      The various GM pumps are similar inside. The difference is in the pressure relief valve & outlet flow restrictor.
      Jun 2009
      Sunbury, PA
      Does anyone know who makes these adapter fittings? I have talked to hot rodders and different distributors and they all say they have heard of them but don't know who makes them.
      Nick
      Mar 2004
      Mid-Michigan
      These Car Craft Articles are good reads... Might answer your questions.
      http://www.carcraft.com/techarticles...e/viewall.html
      http://www.carcraft.com/techarticles...ering_secrets/
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Jun 2006
      Katy,TX
      Talk to Lee. If the box has the later metric thread O ring fittings the threads are close enough for SAE stock fittings to screw in and he has some inserts to replace the O ring with a seal for the flair like in the first article picture. Used them on my 79 Camaro with a later IROC box when I autocrossed it.
      1965 GTO project car
      2004 Pulse Red GTO
      Jun 2009
      Sunbury, PA
      Hey thanks a lot guys. I called Lee and they hooked me up. Thanks again!
