      Nov 2004
      Imperial Beach, CA
      Kinesis wheel upgrade / Fitment Issues
      FRONT REAR
      Torq Thrust Corvette Kinesis Torq Thrust Corvette Kinesis
      Rim Width 8 10 8.5 9.5 12 11
      Back Spacing 4.75 7 6 6.5 9 7.5
      Front Spacing 3.25 3 2.5 3 3 3.5
      Center Line 4.5 5.5 4.75 5.25 6.5 6
      Offset 0.25 1.5 1.25 1.25 2.5 1.5
      Spacer 1.25 1 1.25 0.25
      I have a chance to buy some Kinesis or Corvette Zo6 wheels but i'm not certain I have done the math correct to determine if I need spaceers. Can anyone help double check my math? My reasoning behind the math is to keep the center of the tire in the same location as it sits now. Let me know your thougthts.
      1967 Camaro -377, T56, Complete Ridetech
      1963 Nova SS Convertible - LS1, 2.8L Kenne Bell 8lbs., T56, Scotts Front Clip, HTH Truck Arm
      san diego
      the advertised rim width is usually 1 in narrower than the measure bead width. So an 8" rim would measure 9" and your back space would be measured to the bead.
      you trq thrust column would read
      8
      4.75
      4.25
      Nov 2004
      Imperial Beach, CA
      My mistake. The front spacing didn't play into my calculations. Please disregard the front spacing.
