    Page 1 of 5 1 2 3 4 5 LastLast
    Results 1 to 20 of 83
      Houston, TX
      67 Firebird-Part 2
      After finishing and driving my Firebird for more than a year with the old school Pontiac drivetrain, I kind of grow tired of coming home smelling like raw gas due to an exhaust leak (I think). So I decided to do an LS swap on the car, and put the entire drivetrain for sale to fund my swap. The Mustang I was working on will have to take a back seat.
      Shortly after the drivetrain was sold to a local Firebird enthusiast, I picked up a complete 5.3L/4l60e combo supposedly with 81,000 miles. I did a leak down test and the percentage loss was around 14% for all the cylinders (cold engine) so I think I'm good. Going to use the motor as is (maybe change out the timing chain/oil pump).
      The old Pontiac motor ready to come out.
      LS mounts from DSE.
      Ordered the Mast oil pan, since DSE said the truck oil pan hangs too low and interfere with the frame. Funny the new oil pan costs as much as the entire engine.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      DSE mounts installed
      Just as I suspected, the truck oil pan hangs too low, and contacted the cross member before the mounting holes on the pass side got lined up.
      I guess I have to pull the motor back out, and install the Mast pan, which came today.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Quick update.
      Mocked up the Mast pan, which cleared everything
      Quick shot of the engine/tranny in car
      Initially I was going to mod the T400 crossmember for the 4l60e, but turned out I had to cut it up too much, and it was additional work that I did not want to do. So ordered new BMR crossmember from Summit, along with Dynatech headers. Also I ordered a new fuel injected tank set up from Tanks Inc.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Worked on the fuel tank over the weekend. Got the pump and sender mounted in the tank.
      I decided to make an access hole in the trunk in case I need to remove/replace the fuel pump/sender.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      The sheet metal around the access hole kind of flexes a bit, so I made a trim ring using my new bead roller to help stiffen it up a bit. Not the prettiest, but it works.
      Welded in place.
      Then I made an access cover panel.
      Ordered fuel lines and an fittings. Hoping to wrap up the fuel system in a week or so.
      Tu Ho
      Firebird V2-LS swap
      Jun 2010
      Tu, really sweet! I also dig the access panel idea big time! How did you make the pannel?
      Atlanta GA
      Another asian dude with a musclecar?
      man thats rare!
      May 2009
      Minnesota
      Great job Tu. Keep the updates coming. Your on the second round and mines still stuck in the garage.
      Houston, TX
      man thats rare!
      Yup, I've shocked a few people.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Quote Originally Posted by geberhard View Post
      Woodward Fab bead roller and 22 ga sheet metal.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Thanks Rob.
      Tu Ho
      Firebird V2-LS swap
      Oct 2012
      Nice progress! DSE mount kit works fine with stock subframe?
      Houston, TX
      Quote Originally Posted by im4u2nvss View Post
      Works so far. There is a member on here, i think he goes by tango68ss, who has the same set up.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Quick update
      Mounted the BMR x-member. Overall the parts fit great, but probably will install much easier if the subframe is out of the car.
      Also started running lines for the fuel system. Got Corvette fuel filter/regulator, Swagelok compression fittings
      About $200 worth of braided line/AN fittings.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Mounted Brian Finch's dual vent, and relocated the battery back to the trunk.
      Lines ran for fuel tank. Just have to figure out whether I want to keep the fuel rail inlet on the driver side (stock), or flip it 180*.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      I decided to mock up the truck accessories, and to my surprise, it's too tall. It's probably due to the DSE mounts, since I've reads over LS1tech that some used truck accessories on 1st gen F-body and it clears.
      Time for new LS accessory drives. I really want VA front runner set up, but the price is way out of my league at this point. I may have to get the Holley set up.
      Tu Ho
      Firebird V2-LS swap
      May 2006
      Rhode Island
      Thanks for posting all of this!! I'm hoping to do this conversion at some point. I can't believe that that oil pan is $500!!
      Rene P.
      Birmingham, AL
      I haven't seen anybody run truck accessories in a first gen. The Camaro/GTO setup is pretty compact. I think the C5 Corvette is the most compact. Not sure about the C6 vette stuff.
      Stephen
      Apr 2004
      Cedar Rapids, IA
      subscribing
      Houston, TX
      Quote Originally Posted by srh3trinity View Post
      Rod Prouty's build thread of his 68 has a picture of the truck accessories mocked up. Looks like it cleared the hood. I'm pretty sure that the DSE mounts I'm using raised everything up. On the plus side, nothing from the motor/tranny hangs below the crossmember.
      Tu Ho
      Firebird V2-LS swap
