    Results 1 to 20 of 34
    Thread: C6Z06 brakes
      El Dorado Hills, CA
      C6Z06 brakes
      I have a friend that has a C6Z06 and just got new calipers, rotors, pads, for his and was asking if I may want his old ones. Im not sure if the prices are good or not. Kinda wanted feedback. I have a 68 Camaro with Budnik Fat Lip Fontana's and would love to have these calipers, etc on my car....
      What I'm asking is - what else is needed to get these on my car approx cost wise... I know Tobin from Kore3 is the guy but I wanted to post this up and try to get some ideas ASAP, so I can answer my buddies question if I want them for $1000, they have approx 25k miles on them.... Or is the cost about the same to et them from tobin as a complete kit
      Thx
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      Apr 2013
      You can get remans anywhere from $700-$1200 without a core. If you're like me and would get new rotors and pads anyways, I wouldn't exactly consider it a fantastic deal.
      Dec 2008
      Detroit
      Quote Originally Posted by El_Diablo View Post
      x2... I would try to get the calipers only and see what he says. Not sure what brakes you're currently running, but you may want to download the template Tobin has on the Kore3 website to verify fitment.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      El Dorado Hills, CA
      K, so I've done more work on this setup and I got the calipers, pads, and rotors for $700. Sounds like a decent price. Tobin be expecting some ?'s soon.... I used your template and they will fit behind my 18" Budniks.... So I now will be looking at the brackets and hub needed.....
      Brad
      Dec 2008
      Detroit
      Thats a fair price for used. I paid $600 for mine on the Corvette forum without pads and rotors
      Chris--
      El Dorado Hills, CA
      So from searching and trying to read as much as I could on here, it's looking like I am going to need to space my wheels out a little from the calpier. I have stock disc's now, removing them this weekend. How many on here are running a spacer for their wheels, and will this pose problems with the wheels now sticking out too far? I know that I need new hubs to run these brakes what is/are my best options here, stock drum, Kore3's etc... THX all
      Brad
      Jun 2010
      Oxnard,CA
      If it cleared the template you shouldn't need to space the wheels out. I used the drum brake hub and machined it done on a brake lathe at work. The factory z06 rotor are HEAVY. You can use the kore hub and a 2 piece rotor to lose some weight which is what I'm planning to do when its time to do my brakes. The hubs will move your wheel surface in .25" and then back out the thickness of the rotor so its negligible.
      Chris Lansford
      69 Nova that's never done
      Dec 2008
      Detroit
      Quote Originally Posted by whytry View Post
      I didn't ask, is this a front setup only? If not, make sure you sized both templates as they are different front and rear. Like Canyon said, if you cleared the templates fitment should not be a problem.
      Chris--
      El Dorado Hills, CA
      C6Z06 brakes
      Yes as of right now fronts only
      Thx guys
      Brad
      Dec 2008
      Detroit
      Still Check the Corvette forum from time to time...
      http://forums.corvetteforum.com/c6-p...ake-setup.html
      Chris--
      El Dorado Hills, CA
      Ok so got fronts with Kore3 brackets for the fronts. I'm hoping to get them installed this coming week!! I have looked at everything and I'm missing the bolts that hold the front caliper to the caliper bracket. Any ideas of what they look like or where I can ge them from?
      Thx
      Brad
      Oregon
      Brad, you have an email. The caliper mounting fasteners vary depending on the application, however for the GMSS applications, they are an M14x2 x 35mm hex head cap screw, class 10.9, zinc plated. While not hen's teeth, they're not exactly something you're likely to find at your local hardware or auto parts store, so let us know if we messed up and forgot to include those with your hardware kit and we'll get them out to you ASAP.
      Tobin
      KORE3
      It's what I does.
      El Dorado Hills, CA
      Thx for the amazing follow up Tobin! Brakes hopefully on the car next couple days!!!!
      Brad
      El Dorado Hills, CA
      Oh yeah, just incase wasn't Tobin's fault. My sons decided to help me and took the bolts with them n were pretending to put them in the power wheels escalade. Kids!!
      Brad
      El Dorado Hills, CA
      Ok so I did a test fit today and :(
      The caliper actually hits the face of the wheel. I was wondering in this could pose an issue for me and it did. So what i'm now looking at is either new longer studs and spacers. It looks like I need a good 1/2". I made sure to try the template for caliper clearance on the wheel hoop but wondered about this part.
      Other option is new wheels all around.... Which was trying to avoid....
      Any ideas for me guys?
      Brad
      I would run spacers that get bolted to the hub and have studs built in. Also make sure that the spacers register on the hub and that the spacers have a lip that the wheel can register to.
      Oregon
      Post up some pics so that we get the whole picture of what you have...you mentioned 18" Budnik's earlier that fit the templates...did you download the wrong template? Your front wheels will need about a 1.81" minimum pad thickness to clear the 1.69" front caliper overhang dimension whereas the rears will require 1.56" minimum pad thickness to clear the 1.44" overhang dimension. Unless you specified the brakes you were intending to run when you ordered your wheels from Budnik, it would be very unlikely for them to provide extra thick pads since it costs more.
      A wheel spacer will provide as much clearance as you need for the calipers, but it will also push your wheel out by effectively reducing your backspacing and potentially causing interference issues between the tire and fender.
      The brackets and hoses that you bought from us are compatible with all of the C5 and C6 brake kits, so you could step down to a smaller kit such as the C6 Z51 or base level kits with the smaller calipers. Either of these should fit behind the wheels you have now and still meet or exceed your performance requirements if not necessarily your aesthetic requirements.
      Tobin
      KORE3
      It's what I does.
      El Dorado Hills, CA
      I'll be able to post some pix tomorrow. I'm hoping my wheels studs come in tomorrow and I can get them put on and then should be able to snap some pix off showing where they hit
      I did not specify my brakes when I ordered the wheels from Budnik, but I've also had these wheels for a couple years and might look at some new ones...
      Brad
      El Dorado Hills, CA
      K so I installed 2 7/8 studs and added approx 1" of washers and it clears the caliper.... It was as stock 18x7 Budnik with an extra 1/4" shaved off the center hub section of the wheel itself as at one point in time they rubbed the outside of the inner fenderwell, and that was due to a horrible buy on my part on a prior disc brake upgrade and the disc brakes pushed the wheels out 3/8"
      So if I run a 1" spacer what issues will I run into? It will be probably be on the ground this weekend like I said im trying to get it on the ground for better pics etc...
      Brad
      May 2002
      Northern California
      get some new wheels buddy....: )
      if they clear the caliper they might not clear the outer wheel well or fender. If your gonna run 1" get yourself an adapter spacer. They are much safer.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
