      May 2012
      Hungary
      Country Flag: Hungary
      How can I use C5,C6 brakes with RideTech Tru Turn?
      I bought a 70 Nova and it's time to start thinking on the upgrades I would like to make on it.
      I would like to use the ridetech suspension kit with Tru Turn but I want to use C5 or C6 calipers also. Is there any conversion kit for the Corvette disc brakes on the market that works with the ridetech spindle?
      Dec 2008
      Detroit
      Since the site says you can use aftermarket or OEM disc designed for your vehicle, seems like you would only need a conversion bracket and hubs like the ones Tobin sells at Kore3.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Cincinnati Ohio
      I have C5 front brakes with the tru turn.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      May 2012
      Hungary
      How did you install the discs and the calipers? Kore3 parts?
      Cincinnati Ohio
      Yes i have a kore 3 kit.
      Feb 2007
      Call tobin at kore3 I have the tru trn for my nova and his brackets work with that kit. The only thing that you have to keep in mind is you will need to brackets for a disc spindle not drum. But your phone call with tobin will lead you in the right direction.
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      May 2012
      Hungary
      Quote Originally Posted by brownz View Post
      Ok, thanks!
