      Dec 2011
      Steering Question need help ASAP
      i was out with my car 69 camaro manual steering
      front suspension is rebuilt completely, and as i was parking i heard this popping noise in my car while i was cranking the wheel.
      and now the steering wheel just spins, and tires dont move?
      is it the coupler or would it be the box and all?
      Beach Park IL
      open the hood. Is the rag joint still attached? Did the pitman arm fall off? That's really all it could be.
      Donny
      Dec 2011
      rag joint is still attached if i spin the steering wheel, the upper shaft spins the lower one going to the box does not
      Beach Park IL
      So then the rag joint is not still attached.
      Donny
      Dec 2011
      Not sounding like it. I'll try to crank all the bolts down and see if that helps
      Central CA USA
      Remove the coupler & inspect.
