    Results 1 to 10 of 10
      Mar 2013
      LS2 in 72 Chevelle Questions [URGENT]
      Hello all. I stopped by Dahmer Powetrain here in the Kansas City area awhile ago and ordered myself a 403 stroker for my 1972 Chevelle. It should be done this week.
      -6.0L GM Aluminum Block
      -L92 Rectangle Port Heads
      -Callies/Compstar LSX Crank
      -4.000 stroke
      -24 tooth reluctor
      -Compstar Connecting Rods
      -4340 H-Beam
      SRP Forged Pistons & JE Rings
      - Coated Skirt
      -11:1 Compression
      -Bullet Custom Hydraulic Roller Cam
      -Manley Pushrods
      -PAC Valve springs
      -Professional Products Keyed Balancer
      -Edelbrock L92 Style Victor Intake
      -Quick Fuel 780 Carb
      -MSD Ignition and GM Performance coil packs.
      Dynoed 574 hp @ 6500 rpm and 530 torque @ 5000 rpm
      I'm unsure what to do about the rest of the parts.
      I have been looking and looking and looking and I can't find a direct answer for:
      which headers I need
      what I need to do about the alternator and the brackets so I don't have any interference with the power steering
      which starter
      which electric fuel pump
      which motor mounts
      And anything else I need to make this thing run.
      As for the headers, I am looking at Hooker's 2289 headers, but I hear you have to use a CTS-V oil pan with a chevelle.
      Does anyone sell the brackets and alternator for a 72 Chevelle?
      What kind of plumbing will I need for an electric fuel pump? What kind of fuel pump?
      I plan on going with the 6A ignition from MSD
      My chevelle already has a 4 core radiator, but I want to throw dual electric fans behind it so I won't have to worry about sitting in traffic this summer
      I kind of feel like i'm blazing new trails here, even though i'm not. If you guys could chime in I would really appreciate it. Thanks.
      Dec 2010
      St Louis
      A lot of your questions will depend on trans choice, Z bar vs hydraulic throwout bearing too.
      headers: depends on engine position, z bar
      brackets: pretty much anything fits under the hood, I used truck bracket (came with the motor) and just changed out the power steering pulley ($13).
      Starter: early aluminum block starters had the thick and thin mounting ears. They had a problem breaking and cracking the block. Lots prefer the truck starters, but any will fit. Note GTO stuff is different.
      Pump: I've had a lot of luck with the Mallory 110 and 140.
      Mounts: will depend on trans
      There are a couple dozen detailed threads on A body swaps over at LS1tech converstions page.
      http://ls1tech.com/forums/conversion...2-gm-body.html
      Jun 2010
      Georgia
      headers and mounts, BRP
      brackets: I like the Kwik setup, that's what i'm running on my 71 Cutlass
      go with the fbody pan
      Apr 2013
      Waverly, Ne
      Ive used the dirty dingo mounts (adjustable) and stainlessworks headers, I bought a conversion pan from mast tho f car accessories dont work alt hits the crossmember. truck ones do.
      Jun 2010
      Deployed
      Quote Originally Posted by SparkyRnD View Post
      I would steer clear of "BRP Hot Rods"....Been there, and not happy with their products.
      - I suggest Ebay motor mount adapter plates
      - Corvette Serpentine LS
      - Look at Dynatech and Stainless works for headers
      - LS starter from Rock-Auto (Get the truck version)
      1970 Camaro/DSE build
      I have done this swap but a lot of the parts available now were not back then.
      The Holley oil pan and accessory mounts seem like a no brainer. Factory look and fit and a decent value.
      I have heard good things about the Dirty Dingo mounts. I think having adjustment is a nice thing to have.
      I second a truck starter from Rockauto. LS motors don't have starter issues like some hi-po big and small blocks.
      Find a factory application for the rad fans and 2 fans is a good call. My 500hp 6.0 ran perfect with an old 2 core and a twin fan setup from a 90's Ford Winstar Van. LS motors have a great cooling system.
      Headers are always tricky. You know the Stainless Works are going to fit well but are big bucks. I have heard good and bad about the Hookers. I would look into the Dynatech's to see what kind of feedback they have. I really liked the Edelbrock's I had but you would have to find used.
      Canada
      71 chevelle w/l92, running a holley pan, dirty dingo adj mounts and pace setter 98-02 f body race headers. Had to rotate the rear tube only to fit the stock z bar and the rest was drop in.
      savannah,ga
      Stainless works headers, Speedtech has good fitting parts for the rest, Southern Performance Systems has accessory brackets that fit good, Champ pans work good, the LH8 pan is in my opinion a poor substitute for a properly made oil pan.
      i also recommend avoiding BRP, VERY POOR SERVICE IN MY EXPERIENCE.
      Nov 2011
      I just did a 72 El Camino and used dirty dingo sliders, f body oil pan, 98-02 pace setter headers, truck accessories, external 255 lph pump fed in to stock hard line (just use good compression fittings).
      Dec 2011
      Alabama
      Dirty Dingo slider mounts are a must. Infinite adjustability works great if you have minor issues to account for.
    Tags for this Thread
