    Thread: DSE mini tub
      Jan 2013
      bay area
      DSE mini tub
      Can I mini tub my 69 camaro with a TCI 4 link. Or is the 4 link bar in the way
      Des Moines, IA
      I would give TCI a call.
      Los Angeles, CA
      I can't speak to Camaros, but I know that they interfere on 1st-3rd gen Novas. The outer plate for the upper cradle is designed to work with stock frame rails and tubs.
      All is not lost, though, because you can simply wing off the outer plates on the cradle and weld up the outer ends as opposed to bolting them on. I believe there is more infor on this over on stevesnovasite.com.
      Good luck!
      Don
      Jan 2013
      bay area
      Thanks car guy. I actually went down to see it today. Not necessary to mini tub after all. I can live with 275s.
      Aug 2012
      Southern Oregon
      As car guy stated: Modification of the frame mounts on the TCI 4-link would be necessary. Fortunately, not an issue for you now.
      Walt
      Jan 2013
      bay area
      Walt,
      Thanks, I have another ? I have a 62 nova with a heidts front clip. I had a hell of a time trying to get my motor mount bolts lined up. Have you ever ran into this?
      Beach Park IL
      Did you just get the Heidts clip?
      Donny
      Aug 2012
      Southern Oregon
      Quote Originally Posted by Chevyaddicted View Post
      Walt,
      What type of motor mounts are you using. I have run into that issue when trying to use updated stock type motor mounts with the safety catch feature. I normally use the Energy Suspension motor mounts and haven't had any issues with fit using them.
      Walt
