    Results 1 to 9 of 9
      Oct 2009
      San Diego, CA
      Ignition cuts off with key in run position
      Hopefully this sounds familiar to someone here-
      Car is a '67 Camaro, just fully restored, including all new wiring harnesses. Car is minimally optioned - non-RS, no heater or radio, etc.
      battery is a big Odyssey PC1200 in the trunk. Something has been causing a drain on the battery that I haven't yet diagnosed. It isn't too bad, so I just switch off the electrical system with a battery disconnect switch when the car is not in use.
      Last night I forgot to do that, and this morning the battery was down at 11 volts. I got the car jumped and running but later when I stopped it, couldn't get it restarted, trying for a long time with multiple jump-packs and everything. After the starter and everything cooled off and the battery was externally charged, the car would turn over and fire, but as soon as the key went back off of the "Start" position and go to the "Run" position, the ignition would die. If I held the key in the Start position it would keep running but I didn't want to spin my starter too high. Before this, it had always started and run perfectly.
      A friend put a voltmeter on the coil, and saw 12v when the key was in the Start position (starter turning) but not when in the run position.
      The car has an aftermarket Mallory distributor and coil. The original power wires for the stock distributor and coil, I have going to the distributor, and the distributor then "feeds" power to the coil.
      Of note, this distributor has a circuitboard inside that allows for stuff like a controllable rev limit, and has been repaired once after being shorted out on an engine dyno session.
      I then tried supplying 12v directly to the hot side of the coil but that didn't do anything, it probably was a bad thing to do actually.
      After doing that I pulled the distributor cap and it smelled like something electrical was toast. When turning over the car, it would no longer spark at all.
      So....guesses as to what was the culprit in the "only power to ignition when key is in Start position"? I've been suggested the ignition switch, the coil, the distributor, one guy even though it might have something to do with the horn relay?
      Trying to figure out what parts I need to get ordered to make a race next weekend, and I'll only have the day on Friday to work on it. If I get a coil, distributor, and ignition switch, might that be enough?
      Thanks!!!
