Thread: L33 engine Magnacharger
03-23-2013 #1
2006 5.3L aluminum block L33 engine with 799 (LS2) aluminum heads and Magnuson LS Magnacharger MP112 supercharger.
I purchased the engine in October 2012 from LKQ. It was pulled from a running vehicle and was compression checked. It was very clean and ran well. I still have the engine tags from LKQ. Auction includes an LS2 camshaft that is not installed yet. This set-up should make around 500hp depending on the level of boost you run.
The supercharger was pulled from an LS1 in good running condition when I upgraded to a larger MP122 unit. The injectors are 42lb and the jack shaft is carbon fiber. I re-used the heat exchanger, pump, hoses, etc with the new supercharger so the auction includes the supercharger, intercooler, intake manifold and injectors.
The front serpentine accessory drive is from an LS1 and includes alternator, power steering pump / reservoir, AC compressor, water pump, crank pulley.
Also included is a stock wiring harness and computer.
Seattle, Wa area (98032) $4500.00
