      Mar 2013
      Phoenix AZ
      1968-73 Nova / LS3 Accessory drive
      I'm preparing to start the engine swap with the connect and cruise package, but I need an accessory drive. This will be a driver not a show car so has anyone tried to use GM accessory drives pn 19155066 or 19155067 in a Nova? I am worried about clearance with the sub frame with the low air conditioning compressor location. I really don't want to spend $2K for a trick billet kit. Any help or comments would be appreciated.
      Nov 2011
      Glendale, AZ
      Www.dirtydingo.com
      Mar 2013
      Phoenix AZ
      Dingo has some adaptors for existing LS style truck accessory drives.
      I am starting from scratch and have nothing to work with. The crate engine are bare on the front.
      I would have to buy a complete set up from a truck at the bone yard them add the Dingo stuff.
      The GM accessory drive part numbers I was asking about comes complete with the ps pump the alt, and the AC compressor all brackets and tensioners for about $900.
      It is close on the AC fitment with the subframe but it might be close enough to work. The 19155067 looks like the better fit with the compressor raised up to about the center line of the crank.
