    Results 1 to 15 of 15
      Oct 2006
      LS Conversion headers for first gen F-Bodys (new header being developed)
      Good morning all,
      I am currently developing a LS conversion full length header for the First Gen F-Body to fit the Heidts, DSE and stock sub-frame. I would like to see how many people would be interested in these headers. I'm looking for them to be done by May. If interested in a set please let me know.
      On a side note I had my car on display at the Hot Rod Restoration Trade Show and I will appear on an episode of performance tv.
      Name:  69 Bird Engine.jpg
Size:  118.9 KBName:  69 Bird interior.jpg
Size:  89.6 KBName:  69 Bird HRRTS.jpg
      Marc
      G&G Performance Parts Inc & Customs
      Jan 2011
      Boston, MA
      What's the plan? How are they going to differ from the other brands out there right now? Pricing?
      Santa Clara, CA
      I am already set and I don't know how many units there are out there in the marketplace, but I have an Art Morrison subframe and I think it is relatively popular.... I know their headers are expensive.
      Steve
      Beach Park IL
      We were right next to you in Indy.
      I think a reasonably priced LS header that will clear the steering linkage in all aftermarket subframes and offer great ground clearance will sell quite well.
      Did you happen to see the LS headers from Hooker? The ones with the cast flanges and all the d shaped ports were about 8 degrees out of whack.
      Donny
      Oct 2006
      Quote Originally Posted by 67rally View Post
      The plan is to bring a header to market that corrects the current LS conversion header flaws. (i.e. with the Heidts Pro G subframe full length headers are too low to the ground.) Other headers have other problems. (i.e. too close to the steering shaft or steering box or spark plug wires too close to header)
      Pricing should be very close to the $750 range.
      I checked with other header manufacturers and in order to get a proper fitting header, it has to be a shorty or a custom header; which if your like me I want full length headers without the $1200 price tag.
      Jan 2011
      Boston, MA
      Quote Originally Posted by Fast 82 View Post
      That's what I was looking for. A lot of the LS headers are in the $600-750 range and still don't fit worth a crap. If you can make a good fitting header in that range, you will have an audience. I already bought my swap headers, but if they don't fit, I keep an eye on this thread.
      Aug 2010
      Los Angeles
      I agree with the above. If you can make them work properly and make them affordable then I'm in!
      Mar 2013
      Sorry to hijack here but I wanted to recommend to Donny to get his "eyecrometer" re-calibrated as the D-port investment cast stainless Hooker LS flanges he was refering to were CAD modeled directly from GM files. The port openings do have a strange shape to them as the right side of the port walls have a definate "flat" in them that can be seen in the photo. This may make the the flange ports appear "off" to someone viewing a set of headers diplayed with them on a table top at a show.
      Oct 2006
      Quote Originally Posted by spacepirate View Post
      Ok guys i will keep everyone posted on the progress!
      Beach Park IL
      Quote Originally Posted by Toddoky View Post
      I guess they are only two degrees out of whack, even in the picture they don't match the port. For me the bigger question is why did they cast a D port into the header flange at all. Round would have been easier to fabricate for sure and would have allowed the D port in the head to do its job, prevent reversion, at least that is what I have always been told.
      Thanks for the pic!
      Donny
      Oct 2006
      McKinney, TX
      I would be interested. I have a heidts frame in my 67 and the steering intermediate shaft is interfering with my edelbrock headers. I have a way around it with a fixed u-joint, but would rather have it work with the headers and just the two normal joints.
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Mar 2013
      Thanks for the pic!
      Donny, a D-shaped exhaust port flows better because the short side radius of the port is raised and straighted out, which speeds up gas velocity at the slowest cross sectional area of the port (the floor), not because it creates the step at the bottom of the port if you happen to connect a round header tube to it. The effects of reversion are experienced primarily during lower rpm operation and lessen as rpm's increase. Large amounts of cam profile overlap and long-stroke crankshafts and other factors work to increase reversion as well, which is why it's always a good idea to have your header primaries be slightly larger than the port exit (like these Hooker flanges are) if your engine will be operated in an rpm range where reversion is likely to be present. It is quite common for engines that are designed and tuned primarily for high rpm operation to utilize headers with an EXACT port match to the exhaust ports, like Formula 1 engines for example. when an LS engine is cammed for higher rpm operation like an LS7 or many modified LS engines are, the engine can benefit from a header with a matching shape to the exhaust port, which is how stock LS7 exhaust manifolds are cast (see photo). The Hooker flange was designed off of GM CAD data, as I mentioned previously, to ensure that it would create no shrouding of the ports on any LS head. The only heads it won't be compatible with is an LS7 or GMPP L92 head as they both feature ports that are higher in relation to the bolt hole center lines than any other LS head.
      The 1-3/4" version of the Hooker flanges use a round port to provide a slightly larger step at the floor as you mentioned to provide more anti-reversion influence on the smaller displacement and/or heavy vehicle applications they will usually end up in.
      Katy,TX
      Fast82, what primary tube size would you use? Would you require a paticular motor mount/stand or could I use what DSE sells with its subframe?
      Oct 2006
      Quote Originally Posted by VenturaII View Post
      My plan is 1 7/8 primary tube size.
      Beach Park IL
      Good information! Thanks again.
      Donny
