      Mar 2011
      NY
      power steering hose
      Need to modify my ford power steering hose has this funky end that fits in the rackNot the side that is circled I borrowed pic from another forum. Could I just cut the hardline near the rack then put a 37* flare on with an fitting then run an earls power steering hose to the pump? Problem is the coyote has pump on opposite side pass side so I need a longer hose.
      Feb 2011
      Indpls, IN
      I had a local hose shop modify a hose by crimping a different hose end on. If you just need longer? Have them cut and crimp a longer hose in place.
      Mar 2011
      NY
      ok if i have to I may go that route thanks was hoping for one I could do in the shop.
