      Sep 2009
      Atlanta,Ga.
      Which 5 or 6 speed?
      I know it is an awesome idea to have that 6th gear in your ride but is a 5 speed just as much fun? I had this ride 1970 Cutlass S since 2007 and I am just ready to get it on the road. I want to drive it around the base im stationed at or wherever I feel like taking it. With that being said can a 5 or 6 speed be had or built at a "reasonable" price? If so where should I get my core from. It is going behind a mild BBC 496. The cam is a Lunati SFT. In:249-Ex:257. Hope that helps if any. If any more info is needed to help me reach my goal please feel free to ask. Thanks in advance!
      I am SUCH a rookie to Pro-Touring
      Dec 2010
      St Louis
      Not much in the way of reasonable. You'll be over $3k with a Richmond 5 or 6 speed or a TKO 5 speed. The Richmond is pretty much a bolt in. If you check around, I think the TKOs require tunnel cutting. Although Keisler has a new trans that's supposed to fit the A body tunnel
      If you're ok with tunnel mods, a T56 from an f body LT1 could be made to fit and can be found fairly cheap. You'll also need a hydraulic clutch, electric speedo, and might need a new rear end with the high 6th gear. Forget about a T5 behind a big block.
      Sep 2009
      Atlanta,Ga.
      Thanks for the info. I was actually leaning more towards an LT1 T56. Do you have a souce where to get a core to be rebulit. Im currently ripping through Ebay and Craigslist. The rear end is going to be swapped out for a set of 4.11 gears or something in that range.
