Thread: Locked up 5-speed
Locked up 5-speed
This is the 5spd from my other project, the Beretta, but even though it's FWD the troubleshooting should still be the same. Muncie/Getrag 282.
I broke it drag racing last year and finally got a chance to get it on the table this weekend. I thought I broke a shift fork or something and it was stuck in 4th gear. But upon removal I can see the input shaft was locked solid - ZERO movement. If it was just stuck in 4th it would move by hand when out of the car. It would only "shift" 3-4 and not 1-2 or 5-R.
I split the case and with the extra wiggle room it will shift through all gears (with some serious effort for some) and allows a touch of rotation in the input shaft "out of gear". I have gotten it to spin about 1/4 a few times, but that is all. The forks seem to be fine, so there must be something else going on. I'm gonna try to press the input & output shafts out of the case at work to get a better look. It's gotta be something with 4th gear, but 3rd is in the way and I can't see anything until I get them out of the case.
Any guesses?
