      Jul 2012
      Chicago
      68 Chevelle back spacing help please
      I have a 68 Chevelle SS no mini tubs wilwood disk brakes and calipers all around. I'm about to order forgeline wheels and I measured but since I've never done it before can anyone help with back and rear spacing. I want to run front 18x8 (245/40/18) and rear 18x10 (295/36/18). I believe front spacing would be 4.5 and rear 5.5. Can you guys please help I need to know my tomorrow thanks a lot
      Dec 2008
      Detroit
      Those backspacing sizes look pretty standard. What you need to make sure of is the pad height for brake clearance. I'm sure Forgeline can definitely help with that.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Jul 2012
      Chicago
      Yea i really didnt make no major mods except wilwood calipers and coilovers all around no mini tubs and hope I'm good with 4.5 up front and 5.5 out back
      Jul 2012
      Chicago
      corona,ca.
      4.5 b.s on front sounds right for an 8' rim.5 3/4 to 6" on the rear.brake changes can move your wheels in or out so check with wilwood if the brake kit moves it in or out from stock.with my c5vette swap the rear wheels got moved out 1/8 each side,in 1/4" each side on the fronts.measure!!phil
      72 chevelle.
      Jul 2012
      Chicago
      I called wilwood and they said I changed the rear end to a 9" of notched the frame it would move the placement but if not then it doesn't. But it does move the front .18 of an Inch outward. So would my 4.5 back spacing for the front change And should I go with a 5.5 in the rear
