    Results 1 to 20 of 30
      Phoenix,Arizona
      New Engine Very low on power
      Ok guys, looking for a little guidance. I rebuilt a 5.3 lm7 with all stock bottom end, new bearings throughout. New 4.8l pistons, ls6 cam, intake, tb and injectors. I fired the car for the first time the other day and drove it for the first time today. The problem is, it is extremely low on power and has virtually no throttle response. Engine rpm barely increases even at 3/4 throttle or more. Iam stumped here. Any ideas as to why it would seem to be so low on power? When the car is in park or neutral it will rev up fine though the RPM range and sounds to be fairly healthy.....
      any insight or help is greatly appreciated.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Sep 2007
      Denver
      Fuel pressure &timing come to mind first. Throttle cable? Got lots to check. If this is efi can you datalog and watch parameters?
      David Beckstrom DVM
      Oct 2012
      British Columbia
      Sounds like its in "limp mode". Have you scanned it yet?
      Todd
      '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
      '67 Camaro SS in process. A long, slow, expensive trip...
      How hard can it be...
      Project Obsession
      https://www.pro-touring.com/showthre...ject-Obsession
      Phoenix,Arizona
      i havent check fuel pressure yet, ill def be doing that soon, i did find out that the trans fluid was low. could tht cause the sluggish feel of the engine? I havent scanned it as I dont have a scan tool. It has a factory "base" tune that a local tuner flashed for me
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Long Beach, Ca
      It would be worth your time to pick up a $15 bluetooth OBDII reader and use some sort of Android/IOS device to see all of the parameters of your engine.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Phoenix,Arizona
      where could I get one? I always thought those were expensive
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Long Beach, Ca
      Try Amazon or www.newegg.com. Search for "Bluetooth ODBII Dongle". I know Newegg had one for $12, but it had some mixed reviews.
      You'll need the dongle and an app for your device; such as "Torque" for Android, or Fuel (?) for IOS.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Sep 2011
      Lawler, IA
      When I first fired my LS1 it was super lean. Turned out I failed to ground the fuel pump. Check all your grounds, engine to body, body to chassis, chassis to engine.
      Phoenix,Arizona
      ok, thanks for all the help guys, ill keep all this in mind when troubleshooting
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Oct 2012
      British Columbia
      Also please keep us posted as we can help you dig a little further if needed
      Todd
      Project Obsession
      Phoenix,Arizona
      well I checked a few things the other night, I couldnt find any obvious issues (no vacuum leaks etc), cylinder 7 is definintely missing though. The ignition system checked out, also used a noid light to assure the injector circuit for that cylinder was working. Im starting to think maybe its a bad injector?? Also the transmission was really low. I guess I didnt put enough fluid in when I initially filled it. It took a good 2.5 quarts. I guess that would explain it not wanting to go anywhere when I tried to accelerate. But I still dont get why the engine didnt want to rev under load...
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      The Piedmont Triad, NC
      my Avalanche did that to me a few years ago. Those engine have like a safety feature to reduce power to not damage the engine. I believe the dealer had to replace my PCM after they spent a week replacing stuff and was still getting the same result. It can be a wide range of things triggering the PCM. I'd double check all you sensors and connections, get a scanner
      67 LeMans Convertible
      67 GTO
      69 Camaro Build Thread https://www.pro-touring.com/showthre...ost-Money-quot
      70 Chevelle 400 4spd
      70 Chevelle
      Phoenix,Arizona
      A little update, I think I narrowed it down to the trans being in "limp mode". All the research I did points to this. The engine seems to being running fine but the trans is stuck in third gear (will go into 2nd if done manually) I do have reverse though. So I did a little testing and made sure there is 12v going to the trans and that the VSS is operating (I even swapped it out with a new VSS, no change) From here Im not sure what to do. How do I clear the PCM from limp mode? What else would cause this? Anything else I should check? Any additional help is greatly appreciated.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Phoenix,Arizona
      Ok, so I scanned the PCM and got the following codes;
      P0300--Random Misfire(which I know cyl 7 is missing)
      P0351--Ignition Coil "A" Primary/Secondary Circuit (which doesn't make sense cause its cyl 7 missing, not cyl 1)
      P0740--TCC Circuit
      P0753--Shift Solenoid "A" Electrical
      P0758--Shift Solenoid "B" Electrical
      So Im thinking the reason Im getting all 3 of the transmission related codes at once is because there is an issue with the wiring or connector going to it. It just seems unlikely that all 3 of these things would go wrong with the trans at the same time. Am I wrong for thinking that?? Any Ideas?
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Phoenix,Arizona
      This may be a stupid question, but does the trans/pcm need an electrical input from the shifter to know what gear its been placed into? I only ask becuase Iam using the factory 1980 camaro shifter setup. There is no PNP switch or anything, just the shifter cable. I just know the 4th gen camaros had an electical switch mounted on the shifter itself and I want to make sure this isnt why Im having this problem.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Phoenix,Arizona
      Well I figured it out finally, the company I bought the harness from screwed up and put the wires in wrong in the main trans connector. Luckily I had a factory harness to compare to. The wires were put in 180 degrees backwards in the connector. I had to removed them all, turn the connector 180 and reinstall them. Everything seems to work fine now. I haven't gotten into 3rd or 4th gear yet but it seems to be shifting perfectly fine. Now all I have to do is figure this misfire out....
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      MD
      Doesn't a random misfire mean that multiple cylinders are missing? When I had a bad coil, the OBD told me which cylinder it was. Then I switched the coil to another hole and got the random misfire code for a day or so, and then it switched to just the new cylinder.
      Phoenix,Arizona
      yeah, Im gettin a random misfire code and a code for cylinder 1 missing. Not sure what the deal is since I know that its #7 missing. (cold header after startup) I switched the coil and plug wire to another cylinder to check so maybe thats why its saying "random misfire"? Im hoping the dude who built the harness didnt screw up the wires to the coils. I dont want to have to check all the pins at the PCM
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Phoenix,Arizona
      So far I have; verified good fuel pressure 58-60 psi, checked the plug wires and coil. Swapped the coil/plug wire and the misfire didnt follow the coil. I used a noid light to check the inctor circuits, removed the coil sub-harness and checked all the wires for continuity/resisance, pulled the valve cover and made sure the valves were opening properly, removed the plugs (#7 is clean and shows good continuity and isnt broken internally) I fired up the engine for a few seconds and touched each header and found that cylinder 7 is the only cold one. So far everything I have looked at checks out fine. The only things I havent done is verified good coil driver circuit for cylinder 7 or checked for a physical clog in the injector. Any other ideas??
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Aug 2010
      sounds like a bad #7 coil...... switch it with another cylinder and verify that the new cylinder is misfiring....
