      Feb 2011
      SSBC rotor hat help.
      Anybody out there have a SSBC Part # for a 1.5" aluminum rotor hat. Needs to be on a 5 on 4.5 or 4.75 or 5 on 5. Thanks
      Oregon
      You only get as good as you give...it might help if you provide some additional information such as a mounting pattern bolt circle (8x7.00", 12x8.75", etc), mounting fastener size/type (is the rotor a through hole or tapped), etc.
      I don't know why you need an SSBC hat, however Wilwood has a pretty decent online catalog of their 2-piece rotor hats here.
      Tobin
      KORE3
      It's what I does.
      Feb 2011
      SSBC hats are specific to their own rotor rings. They don't normally sell piece by piece, and don't offer part listing like wilwood. I called a few times, the Gent at SSBC was extremely helpful, but he has to pull prints and figure from there. Didn't know if anyone out there might just a part number handy. I wouldn't mind going through Wilwood, but the cost is kinda crazy on ring replacement.
      Oregon
      I was just thinking that if you posted up the mouting pattern, there may be other options including, but not necessarily limited to Wilwood. That's a bit concerning that SSBC can't answer your question more readily...seems like a standard wear item considering aluminum rotor hats are generally replaced after several disc replacements in practice.
      Tobin
      KORE3
      It's what I does.
      Feb 2011
      Kinda what I thought. It's not that they don't wanna help, they just don't have a simple means to do so. Should be universal. You can order hat/rotors as a replacement, just need the part #. I have their pt# for the ring, just not the hat.
    Tags for this Thread
