    Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
    Results 21 to 40 of 94
    1. #21
      Dallas TX
      These are such cool cars. Good luck with the project. I owned one for a little while a couple years ago. It was one of the most solid cars i have ever seen. The new owner made it a Super Bee clone that is now a record setting car in factory stock racing.
      http://board.moparts.org/ubbthreads/...fpart=all&vc=1
    2. #22
      Colorado Springs
      Quote Originally Posted by MidnightSpecial View Post
      I say the tires and wheels were immediate needs for a few reason. The tires are old and dry rotted, not very save for cruising, much less performance use. But i dont want to spend $500 on tires to fit 15's just to replace them a month or so down the road....i know rebuying is the name of the game with old cars sometimes....just trying to throw the money to the right places..
      Fair enough. It would run you around $600 to replace all your 15" stuff, so if you have a wheel and tire combo selected already, you might as well upgrade to those and save you the expense later. Yes, you want to have confidence your tires are good. This will probably blow your current budget.
      Where can I find the offset control arm bushings? Im guessing they line up to factory?
      Rock Auto, Moog 7103, $24 a pair, you need two pairs for the whole car. These will fit right into your stock upper control arms once the original bushings are removed. These need to be installed the OPPOSITE way of the instructions because they were designed for added camber. You want extra caster instead.
      Im also pretty ignorant when it comes to choosing shocks. Any suggestions to brands or models? Definitely want some that will drop me down a little bit. Car is sitting high right now.
      Luckily i have a friend that can help me with camber and toe. He works at a tire shop and they got all the equipment there for me.
      Thanks for the input. If I could buy you a pack of beer I would haha.
      Get the Bilstein RCD shocks from Hotchkis or Firm Feel. These will work well with your current stuff as well as the potential upgrade stuff later down the line. Also, the shock don't hold up the car. They only control the motion. The springs hold up the car and control ride height. Front ride height is easy to change on a mopar, but before you start messing with this, you need to see how the car looks with those 40 series 18" tires compared to the 78 series you have now. Chances are they will make a big change to the height of things. Once you get those on, then see if you like how things look.
      With the new tires, you'll want to a new alignment so you don't trash them. I'd certainly recommend you try to do those upper bushing at the same time so you set this all up once and be done with it. Whatever you do, DO NOT use the factory specified alignment set up your new tires. First set your ride height where you like it This is done by jacking the front end up in the air and turning the large 3/4 hex bolt in the middle of the lower control arm. Only turn this two complete turns at a time, on both sides, drop the nose back down, and bounce it several times to take a set. This allows you to sneak up on the stance you like. Once that is done, then set the caster/camber/toe. Try for as much positive caster as possible, -.5 degrees camber, and 1/16" inch toe in total since you aren't rebuilding the suspension. If your friend can do this on the rack, it will be easy. Just remember that on a old mopar caster and camber are interdependant and too much of one may not allow you to get enough of the other, so it becomes a compromise to get good settings.
      TonyC@HP2
    3. #23
      Nov 2011
      Massachoosetts.
      Man, an honest to goodness Pro Touring Coronet? I'm psyched to see your project and look forward to the time when my 69 is ready to have its own thread on here. Coronets are my favorite cars of all time, though I'm partial to the 69 (which is why I bought one :D ).
      You got yours for a great deal, good luck with the project, I'll be watching! PS: Check out protouringmopar.com as well. Theres a whole group of us pro-touring minded Mopar fans on there and the advice is free-flowing and all Mopar-related.
      1969 Dodge Coronet Coupe - PT Project
      1974 Dodge Dart Swinger - The Cruiser
    4. #24
      Aug 2011
      North Platte,NE
      The 68 Dodge B-bodies have the sickest taillights of all Mopars IMO. My bro has a 69 1/2 Bee that I would love to make handle.
    5. #25
      Jan 2013
      Mississippi
      Quote Originally Posted by Sneke_Eyez View Post
      I may have posted my project prematurely but I am definitely taking advantage of the help given to me so far. I hope it will be exciting for others as it is for me.
      Also......account created....
      Quote Originally Posted by 72BBSwinger View Post
      I would love to make mine handle too! haha
      In time mine will.....hopefully......or ill just lie about how great it handles
      1968 Dodge Coronet Deluxe
      Build thread:https://www.pro-touring.com/showthre...t-Deluxe-Build
      "Make it three yards, motherf***er, and we'll have us an automobile race."
    6. #26
      Jan 2013
      Mississippi
      So this happened today....lets just say I put new plug wires on in the right firing sequence and the timing was WAY off..... at least that is the only explanation i have.
      Cue the Benny Hill music.
      and it left this on my door
    7. #27
      Mar 2013
      Nice Coronet! I love those cars. A friend in HS had a '70 Super Bee that looked a lot like your's except the front end. I love the blacked grill and hood. I do believe I'd clean up/replace the DODGE letters if it were mine though, just to have a little pop. Are you sticking with red?
    8. #28
      Aug 2011
      North Platte,NE
      Before you settle on wheels, go with 18x10s all the way around. They fit and you run 295/35/18 tires. You said you wanted it to handle right?
    9. #29
      Jan 2013
      Mississippi
      It must be a hell of a tight fit especially if it comes down an inch or two. What kind of offset would it take on the front and back? I see it working in the back but i dont know about the front. Seems like i would have to roll the hell out of the fender. If it can be done its definitely an option I will look at.
    10. #30
      Aug 2011
      North Platte,NE
      Dan at Hotchkis has that wheel/tire combo on his 68 RR. I would call and chat with him. IIRC he said he had room to spare.
    11. #31
      Jan 2013
      Mississippi
      How would i go about getting ahold of that number. Just call up the number on the site and ask for Dan? haha....seems too simple. But if so thats awesome. Says a lot about Hotchkis.
    12. #32
      Aug 2011
      North Platte,NE
      Pretty much it, if he's somewhere else im sure they would give him your number. He is an employee there for sure though.
    13. #33
      Jan 2013
      Mississippi
      Since money is short right now I have been tinkering with the car trying to get it running better. Since i blew my muffler I went ahead and re did the exhaust system. Installed some Flowmaster Super 44's and got a set of Hookers. I also bought a set of new tires because the ones that came on the car were very dry rotted and very unsafe. Went with ole faithfuls for now(as well as cheap) BFG T/A Radial's. Decided to throw on something that worked for now instead of throwing big money at new wheels/tires.
      Oh and i also decided to rattlecan it olive drab green :D
    14. #34
      Jan 2013
      Mississippi
    15. #35
      May 2009
      Connecticut
      That looks so mean
      Aldin
      1969 Camaro (Weapon of Choice) in the works
    16. #36
      Dec 2007
      Lombard, IL
      I never get tired of white letter tires & black steelies on big cars!
      I've been digging that look since Gator McKlusky's LTD in "White Lightning" (1973 movie).
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
    17. #37
      Jan 2013
      Mississippi
      Quote Originally Posted by Zanie View Post
      It was either paint them black or keep them with the overly rusted chrome look haha
    18. #38
      oshawa ontario
      Like it!
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
    19. #39
      Jun 2012
      I've got a set of 1st gen viper calipers, spindles, bearings... All u need is the ARE kit with the brackets and 11.75" rotors from 75 charger...
      I went with the RMS coil over kit for my 68 Coronet r/t (front and rear). Wildwood 13" Challenge kit is on special til end of the month $999 6 piston calipers. Just got my kit last week. NICE! Go with doctor diff rear kit. 650 uses mustang parts and no need to upgrade to green bearings.
      I've just ordered some 19's and 20's Bonspeeds... Paint next month hopefully...
    20. #40
      Jun 2012
      Dan is usually on protouringmopar.com
