    Results 1 to 20 of 25
      Eastern Virginia
      Holley LS accessory brackets.
      Holley has recently released a slew of accessory brackets for the LS motors to aid in swapping to other vehicles. I like the look of their high mount AC brackets. Gets it out of the way while still looking like the other cast brackets.
      http://holley.com/types/LS%20Accessory%20Drives.asp
      Scot
      86 Monte SS
      May 2002
      Northern California
      Wish we had pictures of it installed.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Aug 2006
      You are right I also would like to see how it fits compared to KWIK AC bracket, which I currently have
      72 Camaro RS:SOLD
      68 Camaro:
      LS6 Engine,Tremec TKO 600,5 Speed
      Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors
      St Louis
      The Holley AC bracket I've seen is made to fit the R4 compressor, not a Sanden.
      bowling green,ky
      Quote Originally Posted by garys 68 View Post
      They will offer both. And IMO it looks better than the qwik especially if you r running corvette accy system because it matches exactly the vette alt bracket and doesn't look like a bunch of billet flat stock that's bolted together
      Eastern Virginia
      Bracket pictured above is for the Sanden compressor. Pictured below is for the R4 compressor.
      Not a real picture, but this shows the Sanden compressor bracket installed.
      Got that image from this document:
      http://www.holley.com/data/Products/...R10614rev1.pdf
      Scot
      86 Monte SS
      St Louis
      Good to see another option. When I did my first swap S&P was about the only game in town, and they were expensive. I ended up making my own brackets.
      Kwik went on my second swap. Thinking I'll go with the Holley brackets on the next. They do look good and are priced right.
      Any idea of availability? Buy now, have it ... when?
      ​John Parsons
      Eastern Virginia
      The R4 compressor bracket can be ordered now from Summit. Dunno if it is really available yet.
      So my question is, since I have to buy a compressor anyway, which is better & why? Car originally had the R4 style compressor.
      Scot
      86 Monte SS
      Eastern Virginia
      Scot
      86 Monte SS
      Midwest
      These are nice, and they are not expensive, either.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Bought the R4 brkt couple weeks ago from Pace and had it in a couple days. Installed but still need to pick up a compressor. Nice piece that fits well with the vette brkt.
      We installed the KWIK on the 69 Camaro/LS3 here in the shop, and it's ugly. The cast Holley part looks better. Maybe I'll give Pace a call.
      ​John Parsons
      Jun 2012
      Robin L. told me at ls fest they were on the shelf in BG so getting them is not a problem. They had them on display and they are nice looking
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Metamora, Illinois
      Quote Originally Posted by lolife55 View Post
      Can you post a pic of the installed bracket?
      I really like this bracket. I wish they would also make them for the smaller SD-7 compressor.
      Here are the links and prices listed in Summit.
      AC Bracket $129.95 - http://www.summitracing.com/parts/HLY-20-133/
      Alt/PS brackets 149.95 - http://www.summitracing.com/parts/HLY-20-135/
      AC & Alt/PS bracket kit $249.95 - http://www.summitracing.com/parts/HLY-20-131/
      Eastern Virginia
      20-134 fits an SD7 compressor.
      Scot
      86 Monte SS
      Newbury Park, CA
      I wonder what the belt loading and tracking will be like. The factory arrangement uses a separate belt for the A/C. The W/P wrap % is a bit concerning as well if the above is correct.
      Jul 2011
      NC
      I have a brand NIB vette compressor im not using if your interested- PM with an offer!
      Josh
      "Schism"
      69 camaro
      Eastern Virginia
      There is very little difference in the belt pully coverage on the Holley setup compared to the stock GM setup from the factory. From the factory there is a tension pulley at the location in front of passenger side head.
      Stock GM Corvette setup"
      Scot
      86 Monte SS
      Jun 2012
      Holley has had this bracket on their test wagon since before power tour. I don't think they have a issue with the WP slipping
      Tim
      86 Mustang
