      Jul 2009
      ma.
      ls1 1st gen mount questions/problems
      I am ready to drop the ls1 4l60e into my 69 camaro this weekend and I am doing some pre- measuring.
      I am using dirty dingo mounts with the 3 mount position on the stock small block frame monts with energy suspension polly mounts, for the trans I am using a g-forge crossmember and bought the tall and short polly mount just in case as I was not shure wich to use .
      It looks like I need to use the last holes in the mount adaptors to the rear setting the motor forward but the crossmember is still 3" short on the last hole on the frame.
      has anyone ran into this problem? if so what did you need to do? drill the frame also anyone who used the mounts what position holes did you use? and wich trans mount in the rear..tall or short?
