    Results 1 to 13 of 13
      Aug 2010
      New Albany IN.
      quick question on 04 gto engine/trans
      I know I can research this but I don't have time. In about an hour I am going to look at a 04 gto ls1 and 6 speed trans. I need to know if the shifter location will work in my 69 Camaro and if the gto oil pan will fit. or if there is anything else to take into consideration. I have only researched late model f body stuff because that's all I have seen in my area but this just showed up. Thanks in advance :D
      Birmingham, AL
      The accessory drive tucks in about as good as any. It is almost identical to the F-body drive other than the power steering pump (which I have one for sale if you wind up needing it). I feel like the GTO pans don't work if I remember correctly.
      Stephen
      Aug 2010
      New Albany IN.
      OK thanks. This motor doesn't have the accessories and if I have to still change the pan I'll just stick with the plan of using the L33.
      Birmingham, AL
      I have most of an fbody accessory drive if you decide to buy one.
      Stephen
      Aug 2010
      New Albany IN.
      OK cool.
      Aug 2010
      New Albany IN.
      Just incase something does happen can you go ahead and shoot me a price and a list of what I will get
      Birmingham, AL
      Here is the ad. https://www.pro-touring.com/showthre...-steering-pump
      You would still need things like the alternator, water pump, PS pump, AC compressor and the tensioner that bolts to the head along with the proper Balancer. These things can be picked up on ebay pretty easily. This would give you a good start though.
      Stephen
      Jul 2007
      Olathe, KS
      Quote Originally Posted by corvettekid1973 View Post
      If I recall correctly, the GTO trans does have the shifter mounted much further forward than other implementations so there's a much better chance. This being said, these are both dependent upon what sub you're using and engine placement. Assuming you're using the stock sub, what do you plan on doing for motor mounts?
      Jul 2007
      Olathe, KS
      Double post
      Aug 2010
      New Albany IN.
      I'm using the stock sub frame. I haven't got to deciding on motor mounts yet. That motor and trans sold fast so now I'm just being patient
      Springfield, Mo.
      Shifter location may be better; however, you are going to have to figure something special out for the driveshaft.
      The GTO has a euro-style (three bolt) driveshaft connection to the trans, not a slip yoke. I had my GTO trans modified with an f-body stye rear portion, and that gives you a f-bod style shifter.
      1967 Camaro - Done!
      1968 Camaro - Underway
      Jan 2011
      Boston, MA
      The GTO shifter is further back than the Fbody by a few inches. Theres a forward shifter hole that you can use, but it takes a little work.
      GTO tranny also has different gearing.
      Aug 2010
      New Albany IN.
      Thanks guys I didn't know that stuff at all.
